Synology DS416Play/12TB-RED 4 Bay NAS
Quicklinx: C8C3WS00 Mfr#: DS416PLAY/12TB-RED
  • Celeron
Synology DiskStation DS416play is a 4-bay NAS server with incredible fun. The massive storage capacity allows you to store your entire multimedia library and turns it into a centralized multimedia center. Powered by a hardware transcoding engine, DS416play delivers real-time transcoding of 4K Ultra HD to various kinds of devices you have, giving you a smooth and high quality streaming experience.
  • Massive storage capacity with utmost fun
    Synology DS416play is born to be your ideal, centralized multimedia center with large storage capacity. Equipped with four drive bays, DS416play supports up to 32 TB storage size, therefore all of your favorite videos, photos and music can be easily stored and shared with others. With AES-NI hardware encryption engine built-in, the encrypted data transmission performance can reach over 224.91 MB/s in reading and 142.56 MB/s in writing. DS416play comes with three USB 3.0 ports for high speed external storage exchange. Dual Gigabit LAN with failover support and hot-swappable drive tray design ensure continual service uptime during drive replacement or unexpected LAN failure. Adaptive Load Balancing optimizes the network traffic received and sent by your Synology NAS without the requirement of special network switch. Brightness-adjustable front LED with schedule control provides flexible LED settings that best suit your environment.
  • 4K Ultra HD multimedia bank
    Synology DiskStation DS416play features real-time H.264 single-channel 4K Ultra HD or triple-channel Full HD video transcoding, bringing more complete support to the latest multimedia file formats and contents and allowing easy file sharing across Windows, Mac, and Linux platforms. With Video Station, you can watch movies and TV shows online or directly through the DS video app on Apple TV. Photo Station's intuitive design allows you to effortlessly organize photos into customized categories, smart albums and blog posts, and link them to social networking websites within a few clicks. Audio Station comes with Internet radio and lossless audio formats support and provides music playback via DLNA, AirPlay, and Bluetooth devices (a Bluetooth dongle is required).
  • Anywhere/anytime availability
    QuickConnect and EZ-Internet configure your DS416play to be accessed over the Internet with minimal effort. DS download, DS file, and DS cloud allow file download/access/synchronization from anywhere at anytime.
  • Running on Synology DiskStation Manager (DSM)
    Synology DiskStation Manager (DSM) is a web-based OS that provides private cloud service. It is designed to make your everyday living easier. The built-in Package Center allows you to download and install the packages designed specifically for your unique needs. All will happen with just a few clicks. The simple interface allows you to obtain and configure storage capacity with minimal friction. It provides you with complete control of your personal cloud and lets you access it anywhere. Synology DSM will help you maximize productivity and get more out of your digital assets with minimal fuss.
  • Energy efficient and easy management design
    Synology DS416play is designed with energy efficiency in mind. Not only does it provide dual 92 X 92 mm fan and smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of Wake on LAN/WAN and scheduled power on and off can further reduce power consumption and operation cost. The hard drive hibernation can further reduce power consumption and operation cost. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Synology Disk Station DS416Play - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
20.3 cm x 23.32 cm x 16.5 cm
2.04 kg ()
1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
1 GB
Storage Operating System
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
20.3 cm
23.32 cm
16.5 cm
2.04 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 3 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
DLNA CERTIFIED, UPnP
Security DVR
25
Compression Format
MPEG-2
Frame Rate
30 fps (playback)
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
3 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation
Security Slot Type
Kensington security slot
AES
External power adapter
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 °C
5 - 95%
