Synology DiskStation DS416 is a high-performance and feature-rich 4-bay NAS specifically designed for small businesses and home users to effectively manage, protect and share data. Equipped with comprehensive office applications, DS416 raises working efficiency while securing data with full backup solutions.
Easy backup solutions
To protect your valuable data, DS416 can become a centralized backup destination for consolidating fragmented and unstructured information across your network through a range of options. Advanced backup privilege management makes network backup tasks safer and more efficient. Cloud Station with selective sync and ACL control provides real-time data backup and synchronization among multiple computers and mobile devices. Complete backup solutions such as Backup & Replication minimize the impact of disasters. -
Rich office applications
Synology DS416 runs on the award-winning operating system, Synology DiskStation Manager (DSM), which offers comprehensive applications and features designed specifically for growing businesses. Mail Server turns Synology DS416 into a dedicated mail service provider, while Mail Station, provides a webmail interface for users to access emails stored on Synology DS416. VPN Server offers an easy VPN solution that provides a secure way of connecting to a private LAN at a remote location. RADIUS Server strengthens network security by overseeing wireless access authentication via RADIUS (Remote Authentication Dial-In User Service) networking protocol. -
24/7 security solution
Synology Surveillance Station offers a centralized interface to manage IP cameras deployed in your office or home, allowing users traveling miles away to safeguard the environment by watching live views, recording events, and taking snapshots with a computer or mobile device. DS416 is an ideal surveillance solution as it is capable of hosting up to 25 IP cameras (750 FPS at 720p). In addition to its intuitive setup and hassle-free interface, Surveillance Station features an optimized live view experience with on-screen operations, smart analytic tools like motion detection, and an alert system that sends instant notification through DS cam, SMS, and e-mail. -
Energy efficient with cool and quiet design
All Synology NAS is designed with energy efficiency in mind. Not only does DS416 provide two 92 mm x 92 mm fans and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of Wake on LAN/WAN, multiple scheduled power on/off can further reduce power consumption and operation cost. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
- Synology Disk Station DS416 - NAS server - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 32 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 20.3 cm x 23.32 cm x 16.5 cm
- 2.04 kg ()
- Processor
- 1 x Cortex-A15 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 25
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 32 TB
- 20.3 cm
- 23.32 cm
- 16.5 cm
- 2.04 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- PPTP, L2TP, SMTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
- DLNA CERTIFIED, UPnP
Security DVR
- 25
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
- 3 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation
- Security Slot Type
- Kensington security slot
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- Software Included
- Drivers & Utilities
- OS Required
- TAA Compliant
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
