Equipped with a powerful processor and AES-NI hardware encryption engine, DS218+ delivers exceptional file transfer speeds. Supporting real-time 4K video streaming, DS218+ is ideal not only for protecting critical data but for storing ultra high-definition media contents as well.
Advanced file system for better data protection
The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overhead. While ensuring high-level data integrity, it also offers flexible, efficient data protection and recovery tools. -
4K multimedia server
Access and stream your 4K media content anytime and anywhere. DS218+ supports 4K H.264/H.265 online transcoding via video station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players, that originally do not support Ultra HD formats. -
Digital asset protection
Synology NAS offers advanced security measures to protect against sudden data loss and potential security holes.
- Synology Disk Station DS218+ - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.8 cm x 23.32 cm x 16.5 cm
- 1.3 kg ()
- Processor
- 1 x Intel Celeron J3355 2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA 6Gb/s RAID RAID 0, 1, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 25
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 24 TB
- 10.8 cm
- 23.32 cm
- 16.5 cm
- 1.3 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, FTP, SMB, NFS
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, Access Control List (ACL) support, RADIUS support, iTunes server, FTP server, reset button, bandwidth control, surveillance station, DNS server, Apple Time Machine compatible, cloud backup, VPN Server, anti-virus protection, file station
- Encryption Algorithm
- AES-NI
- DLNA CERTIFIED
Security DVR
- 25
- Compression Format
- MPEG-2, H.264, H.265, VC-1
- Image Resolution
- 4096 x 2160
- Expansion Bays
- 2 (total) / 2 (free) x internal - 2.5" / 3.5"
- 3 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA 6Gb/s
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption, fan speed controller, Hybrid RAID
- Security Slot Type
- Kensington security slot
- FCC Class B certified, RoHS, BSMI Class B
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
Synology D3NS1866L-4G RAM Module | In Stock | £64.44 |
