Synology DS218+2 Bay Diskless NAS
Quicklinx: D47GWS00 Mfr#: DS218+
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Celeron
More than 50 in stock
£275.73 ex VAT
£330.87 inc VAT
Equipped with a powerful processor and AES-NI hardware encryption engine, DS218+ delivers exceptional file transfer speeds. Supporting real-time 4K video streaming, DS218+ is ideal not only for protecting critical data but for storing ultra high-definition media contents as well.
  • Advanced file system for better data protection
    The Btrfs file system introduces advanced storage technologies and optimized snapshots to prevent data corruption and reduce maintenance overhead. While ensuring high-level data integrity, it also offers flexible, efficient data protection and recovery tools.
  • 4K multimedia server
    Access and stream your 4K media content anytime and anywhere. DS218+ supports 4K H.264/H.265 online transcoding via video station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players, that originally do not support Ultra HD formats.
  • Digital asset protection
    Synology NAS offers advanced security measures to protect against sudden data loss and potential security holes.
Synology Disk Station DS218+ - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
24 TB
0 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.3 kg
1 x Intel Celeron J3355 2.5 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA 6Gb/s - RAID 0, 1, JBOD
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
2 GB
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
24 TB
10.8 cm
23.32 cm
16.5 cm
1.3 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
(supported) 2 GB (installed) / 6 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, FTP, SMB, NFS
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, Access Control List (ACL) support, RADIUS support, iTunes server, FTP server, reset button, bandwidth control, surveillance station, DNS server, Apple Time Machine compatible, cloud backup, VPN Server, anti-virus protection, file station
Encryption Algorithm
AES-NI
DLNA CERTIFIED
Security DVR
25
Compression Format
MPEG-2, H.264, H.265, VC-1
Image Resolution
4096 x 2160
Expansion Bays
2 (total) / 2 (free) x internal - 2.5" / 3.5"
3 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA 6Gb/s
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption, fan speed controller, Hybrid RAID
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
External power adapter
Power Provided
60 Watt
5 °C
5 - 95%
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: Synology
Price Range Ex VAT: 150 - 300
