Your basket is empty
Synology DS216j/6TB-RED 2 Bay NAS
Quicklinx: C0C5WS00 Mfr#: DS216J/6TB-RED
DS216j is specifically designed for home and personal users. It is intuitive and powerful, making sure users enjoy effortless data sharing, multimedia streaming and seamless file synchronization. Powered by a built-in floating-point unit, DS216j boosts thumbnail processing, enhancing photo browsing experience, as well as transcoding audio tracks into MP3s on demand to reduce streaming bandwidth.
Synology Disk Station DS216j - NAS server - 6 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
6 TB
Max Supported Capacity
16 TB
2 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
1 x Marvell ARMADA 88F6820 1 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 3 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
10
RAM
512 MB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
6 TB
16 TB
10 cm
22.55 cm
16.5 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, manageable, print server, IPv6 support, IP address filtering, backup server, download client, file sharing, event log, Access Control List (ACL) support, Advanced Data Streaming (ADS), RADIUS support, SSH support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server, anti-virus protection, mobile users support, Wi-Fi USB dongle support
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
10
Compression Format
MJPEG, H.264
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, Google Cloud Print, hardware encryption
FCC Class B certified, RoHS, BSMI Class B
External power adapter
Power Provided
60 Watt
Software Included
Drivers & Utilities, Synology Assistant, DS photo+, DS audio, DS cam, DS file, DS finder, DS video, DS download, DS cloud, DS note
5 °C
5 - 95%
