DS216j is specifically designed for home and personal users. It is intuitive and powerful, making sure users enjoy effortless data sharing, multimedia streaming and seamless file synchronization. Powered by a built-in floating-point unit, DS216j boosts thumbnail processing, enhancing photo browsing experience, as well as transcoding audio tracks into MP3s on demand to reduce streaming bandwidth.
Faster performance on your private cloud
Equipped with an ultimate CPU with a hardware encryption engine, DS216j provides excellent reading speed, providing fast backup, as well as smoother cloud synchronization; while offloading encryption calculation tasks from the main CPU, allowing for faster data transfers. -
Enhanced multimedia processing capability
DS216j brings optimal multimedia experience to home users. Powered by a built-in floating-point unit, DS216j boosts thumbnail processing, enhancing photo browsing experience, as well as transcoding audio tracks into MP3s on demand to reduce streaming bandwidth. -
4-level brightness control for front LEDs
DS216j has adjustable front LED indicators, allowing you to choose between four levels of brightness and set a schedule according to time and day, so you'll get a comfortable and appropriate brightness level. -
Backup data in multiple ways
DS216j is the perfect backup destination for your data. You can back up everything on your computer directly to Synology NAS using Cloud Station. You can specify your backup destination as not only local hard drives, but also connected USB storage devices, or public cloud services. Additionally, Backup & Replication allows you to schedule backup tasks and restore the server to any particular point in time, while minimizing storage consumption and processing time by saving only specific data blocks that are changed between versions. -
Ultimate file center
File Station is a fast and secure feature for sharing and managing your files stored on DS216j. Just drag-n-drop and upload data from PC. Advanced filters make it easy to search for documents, photos, or videos. With built-in FTP or email clients, DS216j lets you organize and share files through an advanced web application effortlessly. You can even share files and folders with others by simply sending a link. -
Stream content to your TV
DS216j is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. -
Eco-friendly NAS server
All Synology NAS is designed with energy efficiency in mind. With special fan and the smart airflow design, the DS216j keeps the system running cool 24/7, while its noise-dampening design makes it quieter than PC counterparts.
- Synology Disk Station DS216j - NAS server - 12 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10 cm x 22.55 cm x 16.5 cm
- Processor
- 1 x Marvell ARMADA 385 1 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 10
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12 or later
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 16 TB
- 10 cm
- 22.55 cm
- 16.5 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 6 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), RADIUS support, SSH support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, eMule client, e-mail notification, cloud backup, VPN Server, mobile users support
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 10
- Expansion Bays
- 2 (total) / 0 (free) x internal - 2.5" / 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption
- Security Slot Type
- Kensington security slot
- RoHS
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- Software Included
- Drivers & Utilities, DS photo+, DS audio, DS cam, DS file, DS finder, DS video, DS download
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95% (non-condensing)
