Product
Synology DS216+II/8TB-RED 2 Bay NAS
Quicklinx: C8BLWS00 Mfr#: DS216+II/8TB-RED
  • Celeron
Fulfill your needs for safe data storage and ultra high definition video sharing with Synology DiskStation DS216+II. Powered by a dual-core CPU, DS216+II comes with hardware-accelerated data encryption and real-time transcoding of 4K Ultra HD source content.
  • Safeguard your data with great performance
    Synology DiskStation DS216+II is designed for small offices pursuing a compact yet powerful shared storage solution. Powered by a dual-core CPU, built-in AES-NI hardware encryption engine and 1GB DDR3 RAM, DS216+II delivers up to an average 113.08 MB/s reading and 111.78 MB/s writing speed, and an encrypted data transmission at over 113.01 MB/s reading and 111.66 MB/s writing under RAID 1 configuration in a Windows environment. DS216+II comes with a front USB 3.0 port with USB copy button for fast and easy data transmission. Hot-swappable drive tray design allows easy installation and maintenance on 3.5-inch HDDs without additional tools. Brightness-adjustable front LED with schedule control provides flexible LED settings that best suit your environment.
  • 4K Ultra HD multimedia bank
    Synology DiskStation DS216+II features real-time H.264 1-channel 4K Ultra HD or 3-channel Full HD video transcoding, bringing more complete support to multimedia file formats and contents. With video station, you can organize personal digital video library with comprehensive media information, watch 4K Ultra HD movies and films, or record TV programs with a DVB-T/DVB-S stick. Photo station's intuitive design allows you to effortlessly organize photos into customized categories, smart albums and blog posts, and link them to social networking websites within a few clicks.
  • Easy backup solutions
    With block-level incremental backup and cross-version deduplication, Synology Hyper Backup provides multi-version backup with optimized storage utilization and allows multiple backup destinations to local shared folders, external hard drives, network shared folders, rsync server, and public cloud services. Synology High Availability Manager ensures seamless transition between clustered servers in the event of server failure with minimal impact to applications to decrease the risk of unexpected interruptions and costly downtime.
  • Energy efficient and easy management design
    Synology DS216+II is designed and developed with energy efficiency in mind. Compared with the average storage server counterparts, DS216+II consumes only 17.4 W in regular operation. The support of Wake on LAN/WAN and scheduled power on and off can further reduce power consumption and operation cost. HDD hibernation can be configured to take effect automatically when the system has been inactive for a specified period of time. This not only saves energy but also extends the lifespan of the hard disks.
Synology Disk Station DS216+II - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
2 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.25 kg
1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA 6Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 4 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
10.8 cm
23.32 cm
16.5 cm
1.25 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap - 3.5"
2 x 4 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, FTP, SMB, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), Syslog support, DoS attack prevention, print server, web server, download client, Access Control List (ACL) support, iTunes server, e-mail server, reset button, DNS server, VPN Server, Wi-Fi USB dongle support
Encryption Algorithm
AES, SSL
DLNA CERTIFIED
Security DVR
25
Compression Format
MPEG-2, H.264
Image Resolution
4096 x 2160
Frame Rate
30 fps (playback)
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 6Gb/s
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation, fan speed controller
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B, TLS
External power adapter
Power Provided
60 Watt
5 °C
5 - 95%
