Product
Brand
Synology DS216+II/8TB-RED 2 Bay NAS
Quicklinx: C8BLWS00 Mfr#: DS216+II/8TB-RED
  • Celeron
Fulfill your needs for safe data storage and ultra high definition video sharing with Synology DiskStation DS216+II. Powered by a dual-core CPU, DS216+II comes with hardware-accelerated data encryption and real-time transcoding of 4K Ultra HD source content.
Synology Disk Station DS216+II - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
2 (installed) / 2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.25 kg
1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA 6Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 4 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
10.8 cm
23.32 cm
16.5 cm
1.25 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap - 3.5"
2 x 4 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, FTP, SMB, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), Syslog support, DoS attack prevention, print server, web server, download client, Access Control List (ACL) support, iTunes server, e-mail server, reset button, DNS server, VPN Server, Wi-Fi USB dongle support
Encryption Algorithm
AES, SSL
DLNA CERTIFIED
Security DVR
25
Compression Format
MPEG-2, H.264
Image Resolution
4096 x 2160
Frame Rate
30 fps (playback)
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 6Gb/s
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation, fan speed controller
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B, TLS
External power adapter
Power Provided
60 Watt
5 °C
5 - 95%
