Fulfill your needs for safe data storage and ultra high definition video sharing with Synology DiskStation DS216+II. Powered by a dual-core CPU, DS216+II comes with hardware-accelerated data encryption and real-time transcoding of 4K Ultra HD source content.
Safeguard your data with great performance
Synology DiskStation DS216+II is designed for small offices pursuing a compact yet powerful shared storage solution. Powered by a dual-core CPU, built-in AES-NI hardware encryption engine and 1GB DDR3 RAM, DS216+II delivers up to an average 113.08 MB/s reading and 111.78 MB/s writing speed, and an encrypted data transmission at over 113.01 MB/s reading and 111.66 MB/s writing under RAID 1 configuration in a Windows environment. DS216+II comes with a front USB 3.0 port with USB copy button for fast and easy data transmission. Hot-swappable drive tray design allows easy installation and maintenance on 3.5-inch HDDs without additional tools. Brightness-adjustable front LED with schedule control provides flexible LED settings that best suit your environment. -
4K Ultra HD multimedia bank
Synology DiskStation DS216+II features real-time H.264 1-channel 4K Ultra HD or 3-channel Full HD video transcoding, bringing more complete support to multimedia file formats and contents. With video station, you can organize personal digital video library with comprehensive media information, watch 4K Ultra HD movies and films, or record TV programs with a DVB-T/DVB-S stick. Photo station's intuitive design allows you to effortlessly organize photos into customized categories, smart albums and blog posts, and link them to social networking websites within a few clicks. -
Easy backup solutions
With block-level incremental backup and cross-version deduplication, Synology Hyper Backup provides multi-version backup with optimized storage utilization and allows multiple backup destinations to local shared folders, external hard drives, network shared folders, rsync server, and public cloud services. Synology High Availability Manager ensures seamless transition between clustered servers in the event of server failure with minimal impact to applications to decrease the risk of unexpected interruptions and costly downtime. -
Energy efficient and easy management design
Synology DS216+II is designed and developed with energy efficiency in mind. Compared with the average storage server counterparts, DS216+II consumes only 17.4 W in regular operation. The support of Wake on LAN/WAN and scheduled power on and off can further reduce power consumption and operation cost. HDD hibernation can be configured to take effect automatically when the system has been inactive for a specified period of time. This not only saves energy but also extends the lifespan of the hard disks.
- Synology Disk Station DS216+II - NAS server - 12 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 12 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.8 cm x 23.32 cm x 16.5 cm
- Processor
- 1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 25
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 12 TB
- 16 TB
- 10.8 cm
- 23.32 cm
- 16.5 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 6 TB
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP, NFS
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, manageable, print server, IP address filtering, web server, backup server, download client, file sharing, event log, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server, anti-virus protection, mobile users support, Wi-Fi USB dongle support
- Encryption Algorithm
- AES, SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 25
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x USB 3.0 - Type A , 1 x eSATA
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, Google Cloud Print, hardware encryption
- Security Slot Type
- Kensington security slot
- FCC Class B certified, RoHS, BSMI Class B, TLS
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- Software Included
- Drivers & Utilities, Synology Assistant
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
