Synology DS1819+ 8TB (8 x 1TB RED) 8 Bay NAS
Quicklinx: DZPVWS00 Mfr#: DS1819+/8TB-RED
  • Atom
DS1819+ is an 8-bay desktop NAS providing superior performance with great expandability, allowing for seamless expansion and upgradability to satisfy your growing business needs.
  • Robust security
    Equipped with AES-NI encryption algorithm and a Kensington security slot, the Synology Disk Station DS1819+ ensures your data is protected with advanced encryption and physical security options.
  • High-capacity storage
    With support for 8 hot-swap drive bays, accommodating both 2.5" and 3.5" drives, this NAS server provides flexible and scalable storage options, making it ideal for growing business needs.
  • Powerful performance
    Powered by a quad-core Intel Atom processor with a clock speed of 2.1 GHz and DDR4 SDRAM, the DS1819+ delivers efficient and reliable performance for handling demanding data management tasks.
  • Versatile connectivity
    Featuring four Gigabit Ethernet ports, two eSATA ports, and support for numerous network protocols, the DS1819+ offers versatile connectivity options for a wide range of networking requirements.
  • Comprehensive surveillance solution
    Supporting up to 40 IP cameras, the DS1819+ serves as a robust surveillance station, providing a scalable solution for your security monitoring needs.
Synology Disk Station DS1819+ - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
Max Supported Capacity
112 TB
8 (installed) / 8 (max)
34.3 cm x 24.3 cm x 16.6 cm
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 1 TB SATA 6Gb/s - Western Digital
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
112 TB
34.3 cm
24.3 cm
16.6 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
8 x 1 TB
Interface Type
SATA 6Gb/s
Manufacturer
Western Digital
Network / Transport Protocol
TCP/IP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Hardware encryption, wake on LAN (WOL), High Availability, download client, event log, Access Control List (ACL) support, FTP server, reset button, surveillance station, DLNA Media Server, cloud backup, VPN Server, anti-virus protection, SSD trim, iSCSI LUN clone/snapshot, cloud station server, MailPlus server
Encryption Algorithm
AES-NI
DLNA CERTIFIED
Security DVR
40
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 2 (total) / 1 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, scheduled power on/off
Security Slot Type
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
1
Max Supported Qty
1
66.96 Watt
Power Provided
250 Watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
22.2 dBA
