Synology DS1817+ (8GB)/24TB-RED 8 Bay NAS
Quicklinx: CWG4WS00 Mfr#: DS1817+ (8GB)/24TB-RED
  • Atom
Synology DiskStation DS1817+ is a 8-bay NAS powered by a quad-core CPU with AES-NI hardware encryption engine. Coming with quad 1GbE LAN ports, it can be installed with a 10GbE network interface card (NIC) or a dual M. 2 SSD adapter card, thereby enhancing network speeds or boosting performance with SSD cache.
Equipped with dual-channel memory and a PCIe slot, DS1817+ supports installing the dual M. 2 SSD adapter card, M2D17, or the 10GbE NIC, for high-IOPS system cache and ultra-fast data transmission respectively.
Synology Disk Station DS1817+ - NAS server - 24 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
24 TB
Max Supported Capacity
80 TB
8 (installed) / 8 (max)
34.3 cm x 24.3 cm x 16.6 cm
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
8 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
24 TB
80 TB
34.3 cm
24.3 cm
16.6 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 3 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 2.0 x8
4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
Internal power supply
61.5 Watt
Power Consumption Stand by
31.6 Watt
Power Provided
250 Watt
Software Included
Drivers & Utilities, Synology Assistant
Limited warranty - 3 years
5 °C
5 - 95%
