- Quad-core 8-bay NAS with AES-NI support, with over 1,179 MB/s reading and 542 MB/s writing performance
- PCIe slot for optional 10GbE add-on card. Four 1GbE (RJ-45) ports with failover and Link Aggregation support.
- Optional M2D17 adapter card for dual M.2 SATA SSDs for cache
- Two memory configurations: 2GB & 8GB with easily upgradable dual-channel design, up to 16GB
- Advanced Btrfs file system offering 65,000 system-wide snapshots and 1,024 snapshots per shared folder
- Scale up to 18 drives with two DX517 expansion units
Synology DiskStation DS1817+ features a quad-core processor with AES-NI hardware encryption engine, providing outstanding performance even with encryption. Supercharge your storage with the optional M.2 SSD adapter card for dual SSD cache drives. DS1817+ is the ideal storage solution for centralizing data backups, protecting critical assets, and sharing files across different platforms. Synology DS1817+ is backed with Synology’s 3-year limited warranty.
Synchronize files across your devices
Cloud Station Suite provides real-time data synchronization across all your devices, such as computers, mobile devices, and other Synology NAS whenever a file is modified. -
Ultimate file management and sharing
File Station is a web-based, fast and secure management tool built to allow easy, drag-and-drop operation without requiring any complex setup on Mac or PC. Advanced search and filtering tools allow for easy organization and sharing of files with just a link. Supports SMB, FTP, AFP, NFS, WebDAV, compatible with any environment. -
Real-time collaboration on your private cloud
Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment. -
Maximize system uptime with Synology High Availability (SHA)
Enjoy a complete hardware and data redundancy solution with Synology High Availability (SHA) in case of unforeseen disasters. After joining two Synology NAS devices to form a high-availability cluster, the NAS acting as the active server will handle all data operations and services, while cloning the entire system to the passive standby server.
- Synology Disk Station DS1817 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Max Supported Capacity
- 80 TB
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 34 cm x 23.3 cm x 15.7 cm
- 5.31 kg ()
- Processor
- 1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- IP Cameras Supported
- 30
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
- 3-year warranty
- NAS server
- Host Connectivity
- Total Storage Capacity
- 0 GB
- 80 TB
- 34 cm
- 23.3 cm
- 15.7 cm
- 5.31 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server
- DLNA CERTIFIED, UPnP
Security DVR
- 30
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x eSATA , 2 x Ethernet 10Gb - RJ-45
- Cables Included
- 2 x network cable
- Wake on LAN, built-in 2 cooling fans
- RoHS
- Power Device
- Internal power supply
- Voltage Required
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 5 - 95%
