Synology DS1618+ 6 Bay Diskless NAS
HIGH-PERFORMANCE & 6-BAY NAS IDEAL FOR TACKLING MULTI-TASK CHALLENGES
Quicklinx: DLM4WS00 Mfr#: DS1618+
  • Atom
High-performance and 6-bay NAS ideal for tackling multi-tasking challenges
User-oriented server with high-speed computing
DS1618+ is a 6-bay NAS that provides storage scalability perfect for tech enthusiasts and small- to medium-sized businesses by effortlessly handling workloads. Further boost storage performance with the optional M.2 SSD cache or enhance network speeds by adding a 10 GbE NIC.
Supercharge your storage with speedy performance
DS1618+ comes with a PCIe expansion slot to support add-in cards. Install a dual M.2 SSD card for high-IOPS system caching and a 10GbE NIC for ultra-fast data transmission.
  • CPU - Quad-core 2.1GHz
  • RAM Options - 4GB DDR4 SO-DIMM, expandable up to 32GB
  • High Performance - 1,151 MBps sequential reading
  • RAID type - More flexible in RAID configuration
Synology DS1618
  • Supercharge your storage with speedy performance
    DS1618+ comes with a PCIe expansion slot to support add-in cards. Install a dual M.2 SSD card for high-IOPS system caching.
  • Ultimate file management and sharing
    The Disk Station has a web-based, fast and secure management tool built to allow easy, drag-and-drop operation without requiring any complex setup on Mac or PC. Advanced search and filtering tools allow for easy organization and sharing of files with just a link.
  • Ultimate backup solution
    DS1618+ integrates various backup applications to safeguard your important data on any device with an intuitive user interface and durable storage technologies.
Synology Disk Station DS1618+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
72 TB
0 (installed) / 6 (max)
28.2 cm x 24.3 cm x 16.6 cm
5.05 kg ()
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
72 TB
28.2 cm
24.3 cm
16.6 cm
5.05 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP, SMB, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Hardware encryption, VPN support, wake on LAN (WOL), Syslog support, High Availability, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, WebDAV server, VPN Server, anti-virus protection, Link Aggregation, failover protection, DLNA support, OpenStack compatible, SSD trim, iSCSI LUN clone/snapshot, Windows ODX, cloud station server, MailPlus server, Rsync compatible, Synology Hybrid RAID
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
6 (total) / 6 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 3.0 x8
3 x USB 3.0 , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, Citrix Ready, VMware Ready
Security Slot Type
Kensington security slot
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
Internal power supply
56.86 Watt
Power Consumption Stand by
25.76 Watt
Power Provided
250 Watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 3 years
5 - 95%
Sound Emission
23.7 dBA
