Product
Brand
Synology DS1515 30TB (5 x 6TB WD Red) 5 Bay Desktop NAS
Quicklinx: B9H3WS00 Mfr#: DS1515/30TB-RED
Synology Disk Station DS1515 is the first 5-bay Value series model with a quadcore CPU, hardware encryption engine, four built-in Gigabit LAN ports and the scalability of up to 15 drives, providing the excellent cost-effective storage solution for growing businesses to efficiently manage, protect, and share data.
Synology Disk Station DS1515 - NAS server - 30 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
30 TB
Max Supported Capacity
30 TB
5 (installed) / 5 (max)
24.8 cm x 23.3 cm x 15.7 cm
4.15 kg
1 x 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
5 x 6 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
30
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
30 TB
30 TB
24.8 cm
23.3 cm
15.7 cm
4.15 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x 1.4 GHz
Number of Cores
Quad-Core
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
5 x 6 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), print server, High Availability, IP address filtering, web server, backup server, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
30
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA , 2 x USB 3.0 - Type A
2 x network cable
Wake on LAN, key lock, built-in 2 cooling fans, hardware encryption
RoHS
TAA Compliant
Internal power supply
Software Included
Synology Assistant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
