Synology DS119J 3TB-RED (1 x 3TB) Bay NAS
Quicklinx: DYV9WS00 Mfr#: DS119J/3TB-RED
Capacity: 3TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
13 in stock
£167.49 ex VAT
£200.98 inc VAT
An ideal first NAS for everyone
DS119j is an ideal entry-level network-attached storage solution for personal users. Fast yet power-saving, DS119j brings an intuitive file management experience with great data transmission speed and extremely low power consumption.
Easy file access with QuickConnect
Access files on your Synology NAS over the Internet without the hassle of setting up port forwarding rules, DDNS, or other complicated network settings. QuickConnect allows you to connect via a secure, customizable address, so that you can instantly access media and work files on any Internet-connected device with no additional charge.
Synchronize files across your devices
Cloud Station Suite provides real-time data synchronization across all your devices and other Synology NAS. "Intelliversioning" keeps the most important file versions to better utilize storage space.
Seamless integration with your mobile devices
Synology mobile applications are designed to allow quick and secure access to your data wherever you are.
Surveillance Station
Complete surveillance solution for recording, monitoring, and management.
Desktop Backup
Simplified backup solution for your Mac, PC, and mobile devices.
File Server/Management
Powerful built-in file management and sharing services.
DSM UI
Award-winning operating system with an intuitive user interface and powerful capabilities.
Security
Comprehensive built-in security tools are constantly updated to tackle evolving threats and protect your devices.
Multimedia
Complete multimedia solution for management, streaming, and playback.
  • Over 108 MBps sequential reading and writing
  • 5.01w in HDD hibernation/10.04w in access
Synology Disk Station DS119j - personal cloud storage device - 3 TB
Personal cloud storage device
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
3 TB
1 (installed) / 1 (max)
7.1 cm x 22.4 cm x 16.6 cm
1 x Marvell ARMADA 3720 800 MHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s
Hard Drive
1 x 3 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
5
RAM
256 MB
Microsoft Windows 7, Windows 10, Apple MacOS X 10.11 or later
Host Connectivity
Gigabit Ethernet
3 TB
7.1 cm
22.4 cm
16.6 cm
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
HDD
1 x 3 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, iSCSI, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, Access Control List (ACL) support, RADIUS support, FTP server, DNS server, VPN Server, file station
Encryption Algorithm
SSL, TLS
Security DVR
5
Expansion Bays
1 (total) / 0 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
External power adapter
5 - 95%
Capacity: 3TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: Synology
Price Range Ex VAT: 150 - 300
