Synology DS116 1 Bay Desktop NAS Enclosure
Quicklinx: C50DWS00 Mfr#: DS116
This compact 1-bay NAS server comes with comprehensive features, allowing you to share and synchronize files across any device wherever you are, boost work productivity, and enhance team collaboration - everything you need for small offices and workgroup environments.
  • A private cloud beyond just data storage
    DS116 lets you do much more than store important digital assets. It allows you to sync files across multiple devices and popular public cloud storage services in one single interface, increase work productivity with collaboration tools, and protect sensitive data with advanced backup packages.
  • Great value, speedy performance
    Powered by a 1.8 GHz dual-core processor, DS116 delivers high speed performance exceeding 112 MB/s writing and 111 MB/s reading. With a dedicated hardware encryption engine, DS116 delivers significantly improved performance when transferring encrypted data, with 112 MB/s encrypted reading and 93 MB/s encrypted writing - an increase in encrypted reading and writing speeds when compared with its predecessor.
  • Dual USB 3.0 ensures high speed data transmission
    The dual USB 3.0 ports offer fast and efficient data transmission to a wide range of external devices. USB 3.0 supports faster transfer speed to external hard drives while consuming less power.
  • Home surveillance, accessible for all
    DS116 serves as your home surveillance hub. Simply connect multiple IP cameras or I/O modules to the home network, pair them with DS116, and then easily view live surveillance feeds, record videos, or enjoy other advanced features like motion detection or push notifications. Support for thousands of IP cameras makes it easy to find compatible models and brands. Safeguard your home, without breaking the bank.
  • Enjoy multimedia library
    DS116 provides you a central platform to organize, backup, and share photos, music, and video collections. Featuring a streamlined and sleek interface, Synology packages let you build a seamless entertainment hub effortlessly. Since everything is saved on DS116, you can enjoy more customizable content arrangement. Better yet, your digital collections can be shared with others via a simple link.
  • Stream content to your TV
    DS116 is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. Synology offers support for TV streaming, meaning you can stream digital content stored on DS116 to your widescreen TV effortlessly.
Synology Disk Station DS116 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
8 TB
1 (installed) / 1 (max)
7.1 cm x 22.4 cm x 16.6 cm
700 g ()
1 x Marvell ARMADA 385 1.8 GHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
16
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
8 TB
7.1 cm
22.4 cm
16.6 cm
700 g ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), print server, IP address filtering, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
16
Compression Format
MJPEG, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
1 (total) / 1 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
External power adapter
Power Provided
36 Watt
Software Included
Synology Assistant
5 °C
5 - 95%
Sound Emission
16.4 dBA
C50D C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
