This compact 1-bay NAS server comes with comprehensive features, allowing you to share and synchronize files across any device wherever you are, boost work productivity, and enhance team collaboration - everything you need for small offices and workgroup environments.
A private cloud beyond just data storage
DS116 lets you do much more than store important digital assets. It allows you to sync files across multiple devices and popular public cloud storage services in one single interface, increase work productivity with collaboration tools, and protect sensitive data with advanced backup packages. -
Great value, speedy performance
Powered by a 1.8 GHz dual-core processor, DS116 delivers high speed performance exceeding 112 MB/s writing and 111 MB/s reading. With a dedicated hardware encryption engine, DS116 delivers significantly improved performance when transferring encrypted data, with 112 MB/s encrypted reading and 93 MB/s encrypted writing - an increase in encrypted reading and writing speeds when compared with its predecessor. -
Dual USB 3.0 ensures high speed data transmission
The dual USB 3.0 ports offer fast and efficient data transmission to a wide range of external devices. USB 3.0 supports faster transfer speed to external hard drives while consuming less power. -
Home surveillance, accessible for all
DS116 serves as your home surveillance hub. Simply connect multiple IP cameras or I/O modules to the home network, pair them with DS116, and then easily view live surveillance feeds, record videos, or enjoy other advanced features like motion detection or push notifications. Support for thousands of IP cameras makes it easy to find compatible models and brands. Safeguard your home, without breaking the bank. -
Enjoy multimedia library
DS116 provides you a central platform to organize, backup, and share photos, music, and video collections. Featuring a streamlined and sleek interface, Synology packages let you build a seamless entertainment hub effortlessly. Since everything is saved on DS116, you can enjoy more customizable content arrangement. Better yet, your digital collections can be shared with others via a simple link. -
Stream content to your TV
DS116 is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. Synology offers support for TV streaming, meaning you can stream digital content stored on DS116 to your widescreen TV effortlessly.
- Synology Disk Station DS116 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 1 (installed) / 1 (max)
- 7.1 cm x 22.4 cm x 16.6 cm
- 700 g ()
- Processor
- 1 x Marvell ARMADA 385 1.8 GHz (Dual-Core)
- Storage Controller
- SATA SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 16
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 8 TB
- 7.1 cm
- 22.4 cm
- 16.6 cm
- 700 g ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), print server, IP address filtering, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 16
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1920x1080, 2048x1536, 1280x800, 2591x1944
- Expansion Bays
- 1 (total) / 1 (free) x internal - 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption
- Security Slot Type
- Kensington security slot
- FCC Class B certified, RoHS, BSMI Class B
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 36 Watt
- Software Included
- Synology Assistant
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 16.4 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
