Compact, lightweight, and energy-efficient, DS115j is perfect for budget-conscious home users looking for a simple, yet feature-rich NAS server. Easily back up documents, monitor live surveillance feeds, or build a personal cloud to share files with friends and family.
Home surveillance, accessible for all
With the Surveillance Station add-on package and two free IP camera licenses, DS115j serves as your home surveillance hub. Simply connect multiple IP cameras to the home network, pair them with DS115j, and then easily view live surveillance feeds, record videos, or enjoy other advanced features like motion detection or push notifications. Support for thousands of IP cameras makes it easy to find compatible models and brands. Safeguard your home, without breaking the bank. -
Backup data in multiple ways
No worries about data loss. DS115j is the perfect backup destination for your data, as it supports Windows Backup for Windows users, whereas Mac users enjoy native Time Machine support. You can choose your backup destination to not only be local hard disks, but also connected USB storage devices. Additionally, Backup & Replication allows you to schedule backup tasks and restore the server to any particular point in time, while still minimizing storage consumption and processing time by saving only the specific data block that has been changed between versions. -
Ultimate file center
File Station is a fast and secure feature to share and manage your files stored on DS115j. Just drag-n-drop and you can upload data from Mac or PC. Advanced filters make it easy to search for documents, photos, or videos. You can reach your files on mobile devices via DS file - a dedicated mobile app for file access, management, and sharing. HTTPS, SSL/TSL encryption, and link expiry dates also ensure file sharing over the Internet at a high security level. -
The most compatible sharing
Enjoy seamless files sharing across Windows, Mac, and Linux platforms as DS115j offers comprehensive network protocol support including FTP, SMB2, AFP, NFS and WebDAV. With Windows AD and LDAP integration, DS115j can fit effortlessly into any existing network environment - there is no need for IT administrators to maintain two sets of credentials. You also won't worry about missing files with the Recycle Bin feature which is supported on AFP, CIFS, File Station, and WebDAV. All files deleted in a shared folder will be automatically moved into the Recycle Bin. -
Your files anywhere with cloud service
DS115j brings you comprehensive cloud service. Cloud Station lets you sync files among DiskStations and multiple devices, including Windows PC, Mac, Linux, iOS, Android, as well as Windows mobile devices, whereas 2-way sync allows file synchronization among different DiskStations. You can even sync files between Google Drive, Dropbox, Baidu and DiskStation - establish your hybrid cloud to enjoy more storage flexibility and prevent data loss. -
Connect your data quickly and easily
Synology aims to provide you the most convenient way to enjoy all services on DS115j. With Synology QuickConnect, you don't have to deal with difficult DDNS setup. QuickConnect frees you from complicated router configuration and port-forwarding, so your entertainment and work files can be accessed on any computer, laptop, or mobile devices instantly without extra charge. -
Enjoy multimedia library
DS115j provides you a central platform to organize, backup, and share photos, music, and video collections. Featuring a streamlined and sleek interface, Synology packages - Photo Station, Audio Station and Video Station - let you build a seamless entertainment hub effortlessly. Since everything is saved on DS115j, you can enjoy more customizable content arrangement and sharing privileges, and no worries about extra monthly fees for storage capacity. -
Stream content to your TV
DS115j is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. Synology offers the latest support for TV streaming, including Samsung TV, Roku players, Apple TV, and Google Chromecast, meaning you can stream digital content stored on DS115j to your widescreen TV effortlessly. -
Eco-friendly NAS server
All Synology NAS is designed with energy efficiency in mind. DS115j only consumes 3.85W in HDD Hibernation and 12.6W in access. With special fan and the smart airflow design, the DS115j keeps the system running cool 24/7, while its noise dampening design makes it quieter than PC counterparts. Synology acknowledges the responsibility as a global citizen, so all Synology products are produced with RoHS compliant parts and packed with recyclable packing materials.
- Synology Disk Station DS115j - NAS server - 4 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Max Supported Capacity
- 6 TB
- 7.1 cm x 22.4 cm x 16.6 cm
- Processor
- 1 x Marvell ARMADA 370 800 MHz
- Storage Controller
- SATA SATA 6Gb/s
- Hard Drive
- 1 x 4 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 5
- RAM
- 256 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 6 TB
- 7.1 cm
- 22.4 cm
- 16.6 cm
Processor / Memory
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 256 MB DDR3
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
Hard Drive
- HDD
- Capacity
- 1 x 4 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- PPTP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP, DDNS
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, VLAN support, Syslog support, print server, IPv6 support, IP address filtering, file sharing, event log, Access Control List (ACL) support, Advanced Data Streaming (ADS), virtual server support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, Virtual Storage, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, e-mail notification, WebDAV server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 5
- Image Resolution
- 1920x1080, 2048x1536, 1280x800, 2591x1944
- Expansion Bays
- 1 (total) / 0 (free) x internal - 2.5" / 3.5"
- 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, Google Cloud Print
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 12.6 Watt
- Power Provided
- 60 Watt
- Software Included
- Drivers & Utilities, Synology Assistant, DS photo+, DS audio, DS cam, DS file, DS finder, DS video, DS download
- OS Required
- TAA Compliant
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 18.1 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
