Synology DiskStation DS416Slim 4bay 2.5" 512MB DDR3 NAS Server
Quicklinx: C27SWS00 Mfr#: DS416Slim
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
£233.62 ex VAT
£280.34 inc VAT
DS416slim is a 4-bay NAS server for drives, aimed at home users and professionals in need of a compact, power-saving, easily transportable storage solution. Accommodating a few disks, it provides all essential services to increase productivity at work or serve as a comprehensive media center solution.
  • High-performance and encryption engine
    DS416slim boasts a powerful processor with a dedicated encryption engine and optimal memory. With link aggregation enabled, DS416slim delivers high reading and writing speeds.
  • Dual LAN with failover and link aggregation support
    Equipped with dual LAN ports, DS416slim ensures continual network service in case one LAN connection fails, decreasing the risk of network downtime. Link aggregation takes advantage of the dual LAN ports to enhance connection speeds beyond the limits of a single cable or port.
  • Painless disk installation and fast fan replacement
    With the detachable fan module, DS416slim makes fan replacement or cleaning easier than ever. At the same time, the snap-in drive tray design allows for fast and neat disk installation. This makes it easy to keep DS416slim clean and running perfectly all the time.
  • Ultra-compact yet functional
    DS416slim weighs little and can be easily transported to serve as a local file and backup servers during off-site assignments. Despite its incredibly compact form factor, it can host large amount of raw data and features two USB 3.0 ports for fast backup from external drives.
  • Stream content to your TV
    DS416slim is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. Synology offers the excellent support for TV streaming, meaning you can stream digital content stored on DS416slim to your widescreen TV effortlessly.
Synology Disk Station DS416slim - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
8 TB
0 (installed) / 4 (max)
10.5 cm x 14.2 cm x 12 cm
660 g
1 x Marvell ARMADA 385 1 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
AC 120/230 V
Storage Operating System
Synology DiskStation Manager
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
8 TB
10.5 cm
14.2 cm
12 cm
660 g
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
L2TP
Remote Management Protocol
SNMP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
LDAP support, wake on LAN (WOL), print server, download client, Access Control List (ACL) support, iTunes server, Samba support, FTP server, e-mail server, surveillance station, DLNA Media Server, Energy Efficient Ethernet, cloud backup, VPN Server, SNMP support, anti-virus protection, Resilient Ethernet Protocol (REP)
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5"
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), hardware encryption
Security Slot Type
Kensington security slot
RoHS
External power adapter
AC 120/230 V
5 °C
5 - 95%
C27S C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
C27S C2G 5m USB 2.0 A/B Cable - Black In Stock £4.98
C27S C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.44
C27S C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.30
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: Synology
Price Range Ex VAT: 150 - 300
