DS416slim is a 4-bay NAS server for drives, aimed at home users and professionals in need of a compact, power-saving, easily transportable storage solution. Accommodating a few disks, it provides all essential services to increase productivity at work or serve as a comprehensive media center solution.
High-performance and encryption engine
DS416slim boasts a powerful processor with a dedicated encryption engine and optimal memory. With link aggregation enabled, DS416slim delivers high reading and writing speeds. -
Dual LAN with failover and link aggregation support
Equipped with dual LAN ports, DS416slim ensures continual network service in case one LAN connection fails, decreasing the risk of network downtime. Link aggregation takes advantage of the dual LAN ports to enhance connection speeds beyond the limits of a single cable or port. -
Painless disk installation and fast fan replacement
With the detachable fan module, DS416slim makes fan replacement or cleaning easier than ever. At the same time, the snap-in drive tray design allows for fast and neat disk installation. This makes it easy to keep DS416slim clean and running perfectly all the time. -
Ultra-compact yet functional
DS416slim weighs little and can be easily transported to serve as a local file and backup servers during off-site assignments. Despite its incredibly compact form factor, it can host large amount of raw data and features two USB 3.0 ports for fast backup from external drives. -
Stream content to your TV
DS416slim is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos. Synology offers the excellent support for TV streaming, meaning you can stream digital content stored on DS416slim to your widescreen TV effortlessly.
- Synology Disk Station DS416slim - NAS server - 0 GB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 10.5 cm x 14.2 cm x 12 cm
- 660 g
- Processor
- 1 x Marvell ARMADA 385 1 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- Synology DiskStation Manager
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 0 GB
- 8 TB
- 10.5 cm
- 14.2 cm
- 12 cm
- 660 g
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- L2TP
- Remote Management Protocol
- SNMP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- LDAP support, wake on LAN (WOL), print server, download client, Access Control List (ACL) support, iTunes server, Samba support, FTP server, e-mail server, surveillance station, DLNA Media Server, Energy Efficient Ethernet, cloud backup, VPN Server, SNMP support, anti-virus protection, Resilient Ethernet Protocol (REP)
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5"
- 2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), hardware encryption
- Security Slot Type
- Kensington security slot
- RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £2.00 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.03 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £12.66 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £16.57 |
