Your basket is empty
Synology DiskStation DS3615 NAS
Quicklinx: B0H3WS00 Mfr#: DS3615XS
  • Core i3
Synology DiskStation DS3615xs provides a premium-performance NAS solution for large scale businesses that require an efficient way to centralize data protection, simplify data management, deploy virtualization solutions, and rapidly expand storage capacity with minimal time spent on setup and maintenance.
Synology Disk Station DS3615xs - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
96 TB
0 (installed) / 12 (max)
30 cm x 34 cm x 27 cm
9.8 kg
1 x Intel Core i3 4130 3.4 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
72
RAM
4 GB
Storage Operating System
Synology DiskStation Manager
5 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
96 TB
30 cm
34 cm
27 cm
9.8 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Network / Transport Protocol
iSCSI, LPR/LPD, SMTP, FTP
Remote Management Protocol
HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP)
LDAP support, wake on LAN (WOL), Access Control List (ACL) support, bandwidth control
Encryption Algorithm
SSL, TLS
Security DVR
72
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 0 (free) x PCI Express x8
2 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 1 x serial (management) - DB-9
2 x network cable
Built-in 2 cooling fans
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95% (non-condensing)
Sound Emission
27.4 dBA
B0H3 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
B0H3 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
B0H3 C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
B0H3 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
B0H3 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
B0H3 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
