Synology ECC RAM module is designed especially for Synology XS-series to expand memory capacity. ECC RAM is predominantly used in servers to combat against the likelihood of errors strikes introduced during data storage or transmission.
- Synology memory - module - 4 GB
- Product Type
- Memory module
- Capacity
- 4 GB
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Designed For
- RackStation RS10613xs+, RS3413xs+
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- ECC
- Compatible Slots
- Memory
- Designed For
- Synology RackStation RS10613xs+, RS3413xs+
