Synology 16GB DDR4 2133MHz CL15 DIMM NAS Memory
Quicklinx: CFRVWS00 Mfr#: RAMEC2133DDR4-16GB
RAM capacity can be expanded on selected Synology NAS servers for boosted performance and responsiveness under high system loads. To ensure the optimum durability and compatibility, select Synology RAM modules.
For RackStation RS3617RPxs, RS3617xs+
Synology - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, unbuffered
Voltage
1.2 V
RackStation RS2418+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Voltage
1.2 V
Synology RackStation RS2418+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+
