Zebra DS6708 Digital Scanner
Quicklinx: 8WGXWS00 Mfr#: DS6708-SR20007ZZR
The versatile DS6700 Series delivers the functionality of a 1-D and 2-D bar code scanner, digital camera and document scanner in a single device. Designed to meet a wide variety of business needs across a variety of industries, the DS6700 enhances employee productivity and streamlines business processes in retail, government, manufacturing and more by combining an onboard 1.3 megapixel camera with high performance scanning features and superior digital imaging technology.
  • Enhance employee productivity
    The DS6700 Series delivers the accurate and rapid first time scanning of bar codes required to maximize employee productivity. Whether you need to read 1-D, 2-D or PDF417 bar codes, the DS6700 Series provides true point-and-shoot bar code capture - there is no need to orient products to the scanner window, and a viewfinder ensures the image is properly captured the first time. Users can dynamically switch between hands-free and handheld operation to quickly, easily and safely scan large items. And a pick list function expands usability from the front room to the back room, enabling rapid processing of orders and more.
  • Superior document clarity for record-keeping applications
    The text enhancement software delivers the document clarity required to streamline record-keeping, replacing paper-based files with electronic filing. From medication prescriptions to bills of lading, the high-resolution camera and text-enhancing software work hand-in-hand to ensure the visibility of text on documents captured, including very small print. As a result, critical business information is literally at your fingertips, helping to reduce administrative and regulatory compliance costs.
  • An outstanding return on investment
    The DS6700 Series reduces capital and operating expenses by eliminating the need to purchase, manage and support additional devices - such as digital cameras and separate bar code scanners for different symbologies. Fewer devices to deploy significantly reduce the time and costs associated with training - and positively impacts productivity. The ability to remotely track, deploy and upgrade DS6700 Series scanners reduces typical management costs. And since even the most intelligent devices require a support plan, Zebra's Service from the Start Advance Exchange Support agreement provides next-business-day delivery of a replacement device for maximum uptime and true service peace of mind.
Symbol Digital Scanner DS6708-SR - barcode scanner
Barcode scanner - handheld - decoded
Twilight black
Minimum Bar Width
5 mil
Scan Element Type
CMOS
Wired
7.1 cm x 11.9 cm x 16.6 cm
182 g
5-year warranty
Twilight black
Barcode
Minimum Bar Width
5 mil
Scan Element Type
CMOS
Light Source Wave Length
630 nm
Scan Mode
Single-pass
Max Working Distance
38.6 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, QR code, MaxiCode, Bookland, Code 32, Code 39 Full ASCII, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Australian Post, Japanese Post, EAN-UCC Composite, Code 128 Full ASCII, Code 39 Trioptic, Dutch Post
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Triggered
1 x barcode scanner
CISPR 24, CISPR 22, CSA 22.2 No. 60950, ICES-003 Class B, FCC Part 15 B, RoHS, Laser Class 2, FCC CFR21 Part 1040, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60825-1, IEC 60529 IP43
No power supply
7.1 cm
11.9 cm
16.6 cm
182 g
Limited warranty - 5 years
50 °C
5 - 95%
Drop Specification
1.8 m to concrete
