Swann Communications Long Range Bullet Camera 1080p
Quicklinx: CMVZWS00 Mfr#: SWPRO-1080FLB-UK
  • Seeing is believing with 1080p (2.1 Megapixels) HD perfect for close up detail such as license plates, faces, clothing colors & more
  • See higher detail over longer distances with a powerful fixed 6mm lens
  • Latest infrared array LEDs produce amazing night vision clarity in low light to 100ft / 30m, with sturdy aluminum camera construction to suit indoor & outdoor applications with IP66 rating for any weather conditions
  • Camera features a built-in microphone so you can see & hear what’s happening^ and longer 100ft/30m cable offers more options when choosing a mounting location for the camera
  • Use the On-Screen Display (OSD) controller & built-in software to customize the camera settings including color, brightness & wide dynamic range for the best video quality every time
  • This camera can be used in combination with other analog HD surveillance technology including AHD, TVI, CVI from Swann & other brands. It’s the perfect addition if you already have a recording solution (DVR) & need extra cameras
  • Deter thieves, safeguard loved ones, protect your property & cut the cost of crime with this superior surveillance camera from Swann
  • Weatherproof cameras built for any climate
    Swann cameras can be mounted indoors and outdoors and are built tough to withstand whatever the weather throws at them: rain, snow, dust and hot days. With IP66 weatherproof rating and cables are threaded through the stand so you can rely on their performance, day in, day out.
  • Clearer night vision with infrared Array LED lights
    Unlike conventional infrared LEDs which display light in a circular pattern that creates a 'spotlight' effect, Array LEDs offer more powerful night vision with amazing clarity with more evenly distributed light than traditional LEDs. The camera is able to see in the dark in black and white up to 100ft (30m) even if it's pitch black, which is more than enough to see anyone approaching your property at night.
  • Built-in microphone adds audio monitoring
    Audio capture adds yet another valuable layer of evidence to your video surveillance for you to hear it live or during playback. Audio could possibly lead to further identification, such as distinguishing someone's voice, as well hear break-in noises and making sure your kids or elderly family members are being well taken care of by anyone assisting them.
  • See longer distances with 6mm fixed lens
    Most cameras will ship with 3.6mm lenses, but the PRO-1080FLB comes with 6mm lenses which have longer focal distance, ideal to catch valuable detail for evidence, such as facial features and license plates of objects standing farther away from the camera while not losing focus of objects closer to the camera.
  • Long cable for reaching more distant mounting locations
    This camera comes with a 100ft (30m) BNC cable. The longer cable will allow you to mount the camera farther away from the DVR, such as at a gate after a long lawn or at large retail spaces.
  • Wide compatibility
    For those techie ones out there, this camera has ample compatibility with a wide range of DVRs and can be used in combination with other analog surveillance technology including 960H, AHD, TVI, CVI from Swann & other brands by using the switch embedded on the camera's cable.
Swann PRO SERIES PRO-1080FLB - surveillance camera
Surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in microphone
6.5 cm x 19.5 cm x 7 cm
620 g
Wired
Camera
Colour - Day&Night
Video Modes
1080p
Optical Sensor Type
2.1 MP
Focal Length Control
Fixed focal
Focal Length
6 mm
Composite video, HD-CVI, HD-TVI, AHD
1 - BNC cable - external - 30 m
Voltage
DC 12 V
Brightness control, Wide Dynamic Range (WDR), infrared cut filter, On Screen Display
Environmental Parameters (operating)
-20 °C - 50 °C
Surveillance camera
Audio Support
Wired
6.5 cm
19.5 cm
7 cm
620 g
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Video Modes
1080p
Infrared LEDs
Infrared Distance
30 m
Image Sensor
2.1 MP
Lens Construction
Fixed focal
Focal Length
6 mm
Horizontal Field of View (degree)
56
Video
Mounting kit, security stickers
1 x BNC cable - external - 30 m
IP66
Power Requirements
DC 12 V
Power adapter - external
-20 °C
50 °C
