Swann Communications Autofocus 4x Zoom Dome Camera 1080p
Quicklinx: CMVYWS00 Mfr#: SWPRO-1080ZLD-UK
£84.36 ex VAT
£101.23 inc VAT
  • Seeing is believing with 1080p (2.1 Megapixels) HD perfect for close up detail such as license plates, faces, clothing colors & more
  • Enjoy vari-focal controls for high quality video in any conditions with the flexibility to go from wide angle viewing to long range zoom
  • Latest infrared cut filter for amazing night vision & clarity in low light to 100ft / 30m, with sturdy aluminum camera construction to suit indoor & outdoor applications with IP66 rating for any weather conditions
  • Camera features a built-in microphone so you can see & hear what’s happening and longer 100ft/30m cable offers more options when choosing a mounting location for the camera
  • Use the On-Screen Display (OSD) controller & built-in software to customize the camera settings including color, brightness & wide dynamic range for the best video quality every time
  • This camera can be used in combination with other analog HD surveillance technology including AHD, TVI, CVI from Swann & other brands. It’s the perfect addition if you already have a recording solution (DVR) & need extra cameras
  • Deter thieves, safeguard loved ones, protect your property & cut the cost of crime with this superior surveillance camera from Swann
  • Weatherproof cameras built for any climate
    Swann cameras can be mounted indoors and outdoors and are built tough to withstand whatever the weather throws at them: rain, snow, dust and hot days. With IP66 weatherproof rating and cables threaded through the stand for extra protection ensure you can rely on their performance, day in, day out.
  • See everything day or night
    At nightfall, the cameras automatically switch to night vision and record in black and white, so that you're sure to record anyone roaming around your property even if it's 3 o'clock in the morning.
  • Built-in microphone adds audio monitoring
    Audio capture adds yet another valuable layer of evidence to your video surveillance for you to hear it live or during playback. Audio could possibly lead to further identification, such as distinguishing someone's voice, as well hear break-in noises and making sure your kids or elderly family members are being well taken care of by anyone assisting them.
  • Round dome shape for discreet surveillance
    Due to their round shape, dome cameras are suitable for those looking for a discreet security camera that easily blends into its surroundings, without drawing much attention to it, such as installing them inside retail stores or inside homes. If you are looking for cameras that are easier to see, you may look at Swann's bullet shaped cameras.
Swann PRO SERIES PRO-1080ZLD - surveillance camera
Surveillance camera - fixed dome - outdoor - weatherproof
Audio
Yes: built-in microphone
13.3 cm x 13.3 cm x 9 cm
670 g
Wired
Camera
Colour - Day&Night
Optical Zoom
4 x
Video Modes
1080p
Optical Sensor Type
2.1 MP
Focus Adjustment
Automatic
Composite video
1 - video cable - external - 30 m
Brightness control, Wide Dynamic Range (WDR), infrared cut filter, On Screen Display
Environmental Parameters (operating)
-20 °C - 50 °C
Surveillance camera
Audio Support
Wired
13.3 cm
13.3 cm
9 cm
670 g
United Kingdom
Camera
Colour - Day&Night - fixed dome - outdoor - weatherproof
Video Modes
1080p
Infrared LEDs
36
Infrared Distance
30 m
Image Sensor
2.1 MP
Lens Construction
Optical Zoom
4 x
Focus Adjustment
Automatic
Video
Composite video
Mounting kit, security stickers
1 x video cable - external - 30 m
IP66
Power adapter - external
-20 °C
50 °C
Brand: Swann Communications
Price Range Ex VAT: 50 - 100
