- Seeing is believing with 1080p (2.1 Megapixels) HD perfect for close up detail such as license plates, faces, clothing colors & more
- Enjoy vari-focal controls for high quality video in any conditions with the flexibility to go from wide angle viewing to long range zoom
- Latest infrared array LEDs produce amazing night vision clarity in low light to 100ft / 30m, with sturdy aluminum camera construction to suit indoor & outdoor applications with IP66 rating for any weather conditions
- Camera features a built-in microphone so you can see & hear what’s happening and longer 100ft/30m cable offers more options when choosing a mounting location for the camera
- Use the On-Screen Display (OSD) controller & built-in software to customize the camera settings including color, brightness & wide dynamic range for the best video quality every time
- This camera can be used in combination with other analog HD surveillance technology including AHD, TVI, CVI from Swann & other brands. It’s the perfect addition if you already have a recording solution (DVR) & need extra cameras
- Deter thieves, safeguard loved ones, protect your property & cut the cost of crime with this superior surveillance camera from Swann
Weatherproof cameras built for any climate
Swann cameras can be mounted indoors and outdoors and are built tough to withstand whatever the weather throws at them: rain, snow, dust and hot days. With IP66 weatherproof rating and cables threaded through the stand for extra protection ensure you can rely on their performance, day in, day out. -
See everything day or night
No matter if it's day or night, you'll be able to see everything up to 100ft (30m) with the powerful infrared night vision. At nightfall, the cameras automatically switch to night vision and record in black and white, so that you're sure to record anyone roaming around your property even if it's 3 o'clock in the morning. -
Built-in microphone adds audio monitoring
Audio capture adds yet another valuable layer of evidence to your video surveillance for you to hear it live or during playback. Audio could possibly lead to further identification, such as distinguishing someone's voice, as well hear break-in noises and making sure your kids or elderly family members are being well taken care of by anyone assisting them. -
Varifocal 4x optical zoom
Much like on a professional photo camera, this camera also features moving lenses for 4x optical zoom, with the advantage that you can control the zooming level remotely both via the DVR or via the Swann app. You'll be able to zoom into important identifiable details, such as faces & license plates with incredible clarity, or just leave on the optimal zoom level that best suits your needs. -
Long cable for reaching more distant mounting locations
This camera comes with a 100ft (30m) BNC cable. The long cable will allow you to mount the camera farther away from the DVR, such as at a gate after a long lawn or at large retail spaces. -
Wide compatibility
For those techie ones out there, this camera has ample compatibility with a wide range of DVRs and can be used in combination with other analog surveillance technology including 960H, AHD, TVI, CVI from Swann & other brands by using the switch embedded on the camera's cable. -
Bullet shaped camera for highly visible surveillance
Due to their shape, bullet cameras are very visible and they also work as a deterrent to intruders. Think about it, if you were a burglar, would you really pick a property that has a video security system installed? On the other hand, if you are looking for more discreet security cameras that easily blend into its surroundings, you may look at Swann's dome shaped cameras.
- Swann PRO SERIES PRO-1080ZLB - surveillance camera
- Surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in microphone
- 7.2 cm x 22.7 cm x 7.5 cm
- 714 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 4 x
- Video Modes
- 1080p
- Optical Sensor Type
- 2.1 MP
- Focus Adjustment
- Automatic
- Composite video, HD-CVI, HD-TVI, AHD
- Cables Included
- 1 - BNC cable - external - 30 m
- Brightness control, Wide Dynamic Range (WDR), infrared cut filter, On Screen Display
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Audio Support
- Wired
- 7.2 cm
- 22.7 cm
- 7.5 cm
- 714 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 30 m
Image Sensor
- 2.1 MP
Lens Construction
- Optical Zoom
- 4 x
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 27 - 90
- Video
- Included Accessories
- Mounting kit, security stickers
- Cables Included
- 1 x BNC cable - external - 30 m
- IP66
- Power Device
- Power adapter - external
- -20 °C
- 50 °C
