Product
Brand
Swann Communications 8 Channel 6 Camera 1080p CCTV Kit
Quicklinx: CMTZWS00 Mfr#: SODVK-845506-UK
  • A cutting edge & easy to use surveillance system with 1080p high definition video to see & protect your premises
  • Set & forget by recording from 8 channels for 160 days+ onto a massive 2TB hard drive
  • Seeing is believing with 6 x 1080p HD cameras offering 100ft/30m infrared night vision & durable construction for indoors or outdoors. Just add 2 more compatible cameras for complete 8 channel monitoring.
  • Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
  • View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
  • Surveillance in the palm of your hand with live viewing on Smartphone & tablets including iPhones, iPads & Android devices using the free SwannView Link app
  • Cut the cost of crime & know what's happening with this expandable HD security system to suit homes, offices, small businesses & retail stores
Swann DVR + camera(s)
System
DVR + camera(s)
Security DVR
8 channels
Hard Drive
1 x 1 TB
Camera
8 cameras - outdoor - night vision
System
DVR + camera(s)
Package Content
8 cameras, DVR, mouse, power adapter, power splitter, security stickers
Video cable - BNC - BNC - 18 m - 8 pcs. , HDMI cable - 1 pcs. , Network cable - RJ-45 - RJ-45 - 1 pcs.
Security DVR
Video Channels
8
Frame Rate (Record)
30 fps
Image Resolution
1280x720
Compression Format
H.264
Record Events
Motion detection, scheduled, manual
Motion detection, smartphone support
Hard Drive
Quantity Installed
1
1 TB
Serial ATA
Removable
Cameras
Quantity
8 cameras
Camera Type
Outdoor
Sensor
1280x720
Field Of View
62°
Night Vision
Infrared Distance
30 m
Voltage
DC 12 V
-20 °C
50 °C
IP67
Video Input Ports
BNC x 8
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 1
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2
Details
DVR: 28.5 cm x 24 cm x 5 cm , Camera: 6.6 cm x 18 cm x 6.6 cm - 363 g
