Swann Communications 4 Channel NVR 2 Camera 4MP POE CCTV Kit
Quicklinx: CMV9WS00 Mfr#: SWNVK-474002-UK
  • Swann’s network video recording security system with 4 Megapixels Super high definition live viewing & playback at 25 fps per channel
  • Includes 2 x security cameras capable of generating Super high definition 4 Megapixels (75% more than 1080p) video with IR cut filters for powerful night vision to 100ft/30m & a weather-resistant rating of IP66 for indoor & outdoor use. Add 2 more compatible cameras for complete 4 channel monitoring
  • You can also hear what’s happening as each camera has a built-in microphone for crystal clear audio
  • Set & forget by recording continuously from 4 channels for 160 days+ onto a massive 1TB hard drive (expandable to 6TB)
  • Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
  • Security in the palm of your hand with live viewing on your Smartphone or tablet including iOS (iPhone, iPad) & Android devices using the free SwannView Link app
  • View live in HD on your HDTV via HDMI or VGA connection to your LCD screen
  • Professional surveillance system gives you peace of mind by being able to see the detail you need from longer distances including license plates, faces, clothing colors & more, all in Super HD
Swann SWNVK-474002 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
4 channels
Hard Drive
1 x 1 TB
Camera
2 cameras - outdoor - night vision
System
DVR + camera(s)
Package Content
2 cameras, DVR, mouse, power adapter, 4 security stickers
Network cable - RJ-45 - RJ-45 - 18 m - 2 pcs. , Network cable - RJ-45 - RJ-45 - 1 m - 1 pcs. , HDMI cable - 1 pcs.
Security DVR
Video Channels
4
Frame Rate (Playback)
25 fps
Image Resolution
1920x1080
Compression Format
H.264
Record Events
Motion detection, scheduled, manual
Mobile phone monitoring, smartphone support
Hard Drive
Quantity Installed
1
1 TB
Cameras
Quantity
2 cameras
Camera Type
Outdoor
Sensor
4 Megapixel
Field of View
75°
Night Vision
Infrared LEDs
Infrared Distance
30 m
Voltage
DC 12 V
-20 °C
50 °C
IP66
Video Input Ports
RJ-45 x 4
Video Output Ports
HDMI x 1, VGA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2, eSATA x 1
Details
DVR: 25.5 cm x 23 cm x 5.1 cm , Camera: 6.6 cm x 18.8 cm x 6.6 cm - 436 g
