Product
Swann Communications 4 Channel DVR 1080p
Quicklinx: CMVJWS00 Mfr#: SODVR-44550H-UK
£192.76 ex VAT
£231.31 inc VAT
  • A cutting edge & easy to use surveillance system with 1080p high definition video to see & protect your premises
  • Set & forget by recording from 4 channels for 160 days+ onto a 1TB hard drive
  • Just add up to 4 compatible cameras for complete 4 channel monitoring
  • Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
  • View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
  • Surveillance in the palm of your hand with live viewing on Smartphone & tablets including iPhones, iPads & Android devices using the free SwannView Link app
  • Cut the cost of crime & know what’s happening with this HD security system to suit front & back doorways, yards, homes, offices, small businesses & retail stores
Swann DVR4-44550 - standalone DVR - 4 channels
Standalone DVR - 4 channels - networked
Compression Format
H.264
TV System
NTSC/PAL
Image Resolution
1920x1080
Hard Drive
1 x 1 TB
Hard Drive(s) Supported
Total capacity: 3 TB
21.5 cm x 24 cm x 4.5 cm
Country Kits
United Kingdom
Standalone DVR
Video Channels
4
Audio Channels
4
TV System
NTSC/PAL
Image Resolution
1920x1080
Compression Format
H.264
Package Content
DVR, external power adapter, mounting kit, mouse
Network cable - RJ-45 - RJ-45 - 1 pcs. , HDMI cable - 1 pcs.
Country Kits
United Kingdom
Security DVR
Record Events
Motion detection, scheduled, manual
Networked
Smartphone support, 'Peer to Peer' technology
Hard Drive
Quantity Installed
1
1 TB
Serial ATA
Supported Max Total Capacity
3 TB
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX
Video Input Ports
BNC x 4
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 1
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2
21.5 cm
24 cm
4.5 cm
Brand: Swann Communications
Price Range Ex VAT: 150 - 300
