SuperMicro X10SRL-F C612 DDR4 ATX Motherboard
Quicklinx: CR4FWS00 Mfr#: MBD-X10SRL-F-B
The new Supermicro's X10 UP Serverboards offer the latest Xeon E5-2600/1600 v3 technology solutions with the highest levels of performance in different form factors to meet various application needs. X10SRL-F, with 7x PCIe (up to 5x PCIe 3.0 x8) slots onboard, is the best choice to maximize your I/O intensive application demand. On the other hand, X10SRi-F offers the latest virtualization support at low cost. For customers who need multiple I/O solutions in a 1U chassis, X10SRW-F (up to 3x AOC) and X10SRG-F (up to 5x AOC) provide the ultimate solutions. Supermicro's first UP Storage serverboard, X10SRH-CF/-CLN4F, brings the latest SAS3 (12Gb/s data rate) technology to the market with the best performance per dollar value.
SUPERMICRO X10SRL-F - motherboard - ATX - LGA2011-v3 Socket - C612
Motherboard - ATX
Chipset Type
Intel C612
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Xeon E5-2600 v3 series, Xeon E5-1600 v3 series, Xeon E5-2600 v4 series, Xeon E5-1600 v4 series (supports CPUs with up to 22 cores, Maximum TDP 145 Watt)
Max RAM Size
1 TB
RAM Supported
8 DIMM slots - DDR4, ECC, registered, Load-Reduced, 3DS Load-Reduced
Storage Ports
10 x SATA-600 (RAID)
USB / FireWire Ports
3 x USB 3.0 + 2 x USB 2.0 + (1 x USB 3.0 + 6 x USB 2.0 via headers)
Graphics
ASPEED AST2400
LAN
2 x Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
Intel C612
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
1 TB
DDR4
Bus Clock
2400 MHz, 1600 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, Load-Reduced, 3DS Load-Reduced
Details
256 GB - registered - ECC , 512 GB - Load-Reduced - ECC , 1 TB - 3DS Load-Reduced - ECC
Graphics
Graphics Controller
ASPEED AST2400
LAN
Network Controller
Intel I210
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin (1.2 V) , 2 x PCIe 3.0 x16 (x8 mode) , 2 x PCIe 3.0 x8 , 2 x PCIe 3.0 x8 (x4 mode (auto-switch to 1 x8 and 1 x0)) , 1 x PCIe 2.0 x8 (x4 mode)
Storage Interfaces
SATA-600 -connectors: 10 x 7pin SATA - 10 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x VGA , 2 x USB 3.0 , 1 x serial , 1 x management
Internal Interfaces
6 x USB 2.0 - header , 1 x USB 3.0 - header , 1 x USB 3.0 - Type A , 1 x serial - header
BIOS Type
AMI
BIOS Features
APM 1.2 support, flash virus protection, power failure recovery (AC loss resume), DMI 2.3 support, UEFI BIOS, ACPI 4.0 support, SMBIOS 2.7.1 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Sleep / Wake Up
Keyboard wake up, RTC (real-time clock) wake up
Hardware Features
Diagnostic LEDs, chassis intrusion detection, WatchDog Timer
I/O back cover
2 x Serial ATA cable
Plug and Play, RoHS, ACPI 4.0
30.5 cm
24.4 cm
Package Type
Bulk
Limited warranty - parts - 1 year , Limited warranty - labour - 3 years
