SteelSeries QcK Gaming Mousepad
Quicklinx: 69C7WS00 Mfr#: 63004
Stock Status: Clearance
10 left in stock
£10.99 ex VAT
£13.18 inc VAT
The SteelSeries QcK is a dream of a mouse pad for every gamer that prefers cloth mouse pads. Having been released in November 2004 this mousepad went through extensive testing by gaming professionals before its release and with their feedback the SteelSeries QcK was further developed, to make it the ultimate cloth pad every gamer desired.
With the use of high quality cloth material, an optimized texture which guarantees both smoothness and glide and a specially designed non-slippery rubber base this mouse pad blows away the competition and is a great choice not only for the hardcore gamer but also for graphic designers and others who use their mouse for extended periods of time.
The SteelSeries QcK is compatible with all types of mice and is ideal for starters because of its great value for the money.
NON-SLIP RUBBER
The QcK mousepad has a non-slip, rubber base that prevents the pad from moving during use. The rubber bottom also supplies additional comfort for your hand and wrist movement at all times.
TESTED BY PROS
The SteelSeries QcK series has undergone intensive testing by professional gamers ensuring that the QcK series provides users with a reliable surface for optimal functionality of your mouse.
CLOTH SURFACE
The cloth surface of the QcK provides a smooth, steady glide surface for gamers available in multiple sizes, thicknesses and designs.
TRUE VALUE
The QcK series are some of the most used mousepads amongst professional gaming teams.
AND THE NUMBERS
-Height: 2 mm (0.08 in)
-Width: 320 mm (12.6 in)
-Length: 285 mm (11.2 in)
  • RUBBER BASE
    Specially designed, non-slip rubber base prevents the pad from sliding.
  • SIGNATURE SURFACE
    The flagship surface for SteelSeries’ professional team and publisher branded options.
  • GUARANTEED GLIDE
    High quality cloth with optimized surface ensures a precise and consistent glide
SteelSeries QcK - mouse pad
Mouse pad
Product Material
Rubber, cloth
32 cm x 27 cm
Mouse pad
Product Material
Rubber, cloth
32 cm
27 cm
Thickness
0.2 cm
Brand: SteelSeries
Price Range Ex VAT: 0 - 50
