Product
StarTech.com XGI Volari Z7 16 MB PCI VGA Video Adapter Card
Quicklinx: 5FR8WS00 Mfr#: PCIVGAV7
Add high quality VGA video to your server, POS system or PC through a PCI expansion slot.
The PCIVGAV7 16 MB PCI VGA Video Card is the ideal addition to servers, thin clients, POS systems and Industrial PC systems that require a cost-effective, yet high quality graphics solution. The video card's low power consumption design eliminates the need for fan/heatsink video card cooling, making this card the ideal solution for embedded and critical environment applications.
Based on the highly optimized memory Architecture of the efficient XGi Volari Z7 chipset, the PCIVGAV7 PCI VGA Video Card supports color depths of up to 16.7 Million colors, and supports 2D Resolutions of up to 1280x1024 @60Hz (32-bit) and 1600x1200 @ 75Hz (16-bit).
StarTech.com XGI Volari Z7 16 MB PCI VGA Video Adapter Card - graphics card - Volari Z7 - 16 MB
Graphics card
Bus Type
PCI
Graphics Engine
XGI Volari Z7
16 MB DDR
Max Resolution
1600 x 1200
VGA
1.9 cm x 16 cm x 12 cm
Package Type
Retail
2 years warranty
Graphics card
Bus Type
PCI
Graphics Engine
XGI Volari Z7
Max Resolution
1600 x 1200 at 75 Hz
VGA
Size
16 MB
DDR SDRAM
SunSoft Solaris, Novell NetWare, Microsoft Windows 2000 Server, FreeBSD, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Vista / 2000 / XP
Software Included
Drivers & Utilities
FCC, RoHS
1.9 cm
16 cm
12 cm
66 g
Package Type
Retail
-10 °C
85 °C
5FR8 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
5FR8 StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £10.05
