Add high quality VGA video to your server, POS system or PC through a PCI expansion slot.
The PCIVGAV7 16 MB PCI VGA Video Card is the ideal addition to servers, thin clients, POS systems and Industrial PC systems that require a cost-effective, yet high quality graphics solution. The video card's low power consumption design eliminates the need for fan/heatsink video card cooling, making this card the ideal solution for embedded and critical environment applications.
Based on the highly optimized memory Architecture of the efficient XGi Volari Z7 chipset, the PCIVGAV7 PCI VGA Video Card supports color depths of up to 16.7 Million colors, and supports 2D Resolutions of up to 1280x1024 @60Hz (32-bit) and 1600x1200 @ 75Hz (16-bit).
- StarTech.com XGI Volari Z7 16 MB PCI VGA Video Adapter Card - graphics card - Volari Z7 - 16 MB
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- XGI Volari Z7
- Memory
- 16 MB DDR
- Max Resolution
- 1600 x 1200
- Interfaces Details
- VGA
- 1.9 cm x 16 cm x 12 cm
- Package Type
- Retail
- 2-year warranty
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- XGI Volari Z7
- Max Resolution
- 1600 x 1200 at 75 Hz
- VGA
- Size
- 16 MB
- Technology
- DDR SDRAM
- OS Required
- SunSoft Solaris, Novell NetWare, Microsoft Windows 2000 Server, FreeBSD, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Vista / 2000 / XP
- Software Included
- Drivers & Utilities
- FCC, RoHS
- 1.9 cm
- 16 cm
- 12 cm
- 66 g
- Package Type
- Retail
- Limited warranty - 2 years
- -10 °C
- 85 °C
