Connect a PCIe M.2 SSD (NVMe or AHCI) to your computer through PCI Express for ultra-fast data access. Get ultra-fast data access by adding a PCIe M.2 SSD to your existing computer. This adapter lets you add a high-speed, 4-lane M.2 SSD (PCIe-based), such as a Samsung 950 Pro or Samsung SM 951, to a PC with an available x4 PCI Express expansion slot. You can mount the PCIe M.2 drive directly onto the adapter, giving you an easy and convenient way to improve your system performance and expand overall internal storage.
The expansion card lets you take full advantage of the fast performance and compact size of PCIe M.2 internal solid-state drives. The adapter connects directly to your computer motherboard to support an M.2 PCIe-based SSD (NVMe or AHCI) through ultra-fast x4 PCIe. The adapter is compatible with PCIe 3.0 motherboards and is also backward compatible with PCIe 2.0 and PCIe 1.0. With the M.2 PCIe based drive in place, the adapter gives your computer a significant speed boost.
The adapter supports PCIe 3.0 x4 NVMe (M Key) and PCIe-AHCI M.2 SSDs including 2242, 2260, 2280, and 22110 drives. The expansion slot adapter supports the most common drive sizes including 110 mm, 80 mm, 60 mm and 42 mm.
The expansion card is equipped with a full-profile bracket and includes a half-height/low-profile bracket, for installation in small form-factor computers.
- StarTech.com M2 PCIe SSD Adapter - x4 PCIe 3.0 NVMe / AHCI / NGFF / M-Key - Low Profile and Full Profile - SSD PCIe M.2 Adapter (PEX4M2E1) - interface adapter - M.2 Card - PCIe x4
- Interface adapter - plug-in card
- Bus Type
- PCIe x4
- Red
- Supported Form Factor
- Expansion Slot to M.2
- Expansion Bays
- 1 x internal - M.2
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- 2.2 cm x 17.8 cm x 8 cm
- 42.2 g
- 2-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- M.2
- Host Bus
- PCIe x4
- Red
Storage Controller
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- Bays
- Included Accessories
- Low-profile bracket, full-height bracket, half-height bracket
- FCC, RoHS, WEEE, RCM
- Limited warranty - 2 years
- 2.2 cm
- 17.8 cm
- 8 cm
- 42.2 g
- 5 °C
- 50 °C
- 15 - 90%
- Designed For
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.53 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £23.25 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £56.93 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £35.63 |
StarTech.com M.2 RAID Controller Card PCIe | In Stock | £65.07 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £23.33 |
StarTech.com 3PT M.2 SSD Card - PCIe 3.0 | In Stock | £32.12 |
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.56 |
StarTech.com M.2 SATA Raspberry Pi Adapter | In Stock | £20.34 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £35.34 |
StarTech.com M.2 to U.2 Adapter | In Stock | £26.40 |
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £55.05 |
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure | In Stock | £59.24 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £54.80 |
StarTech.com Dual M.2 PCIe SSD Adapter Card | In Stock | £70.75 |
StarTech.com M.2 to U.3 Adapter/Converter | In Stock | £34.61 |
