StarTech.com Wireless Presentation Remote
Quicklinx: D9KPWS00 Mfr#: PRESREMOTE
More than 50 in stock
£25.59 ex VAT
£30.70 inc VAT
This presentation remote control helps you deliver seamless presentations by combining intuitive navigation and a laser pointer in a single compact unit.
Being confined to your computer isn't the most effective way to deliver a presentation, especially when you're trying to engage your audience.
With a wireless range of 90 ft. (27 m), this presentation clicker puts you in control of what's on your screen, giving you the freedom to move around the room while controlling your presentation as if you were at your computer. This is ideal for presenting in large lecture halls or conference centers.
With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share with your audience.
The remote control features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it. The USB receiver is supported by generic HID drivers ensuring it will work with virtually any Mac or Windows computer.
StarTech.com Wireless Presentation Remote w/ Red Laser Pointer - 90' presentation remote control
Presentation remote control
3.1 cm x 13.4 cm x 6.6 cm
120 g
Radio
Max Operating Distance
27 m
2 AAA type
3.1 cm
13.4 cm
6.6 cm
120 g
Radio
27 m
Built-in laser pointer, built-in receiver dongle storage
Connector Type
1 x USB (4 PIN USB Type A)
Operating System
Apple Mac OS, MS Windows
Storage case, USB receiver, 2 AAA batteries
FCC, RoHS, WEEE
5 °C
45 °C
30 - 80%
2 AAA type
D9KP StarTech.com Wireless Presentation Remote In Stock £25.59
D9KP StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90’ In Stock £35.84
Price Range Ex VAT: 0 - 50
