Split the audio from your iPod / MP3 player to two sets of headphones. The MUY1MFFADPW White Slim Headphone Splitter Cable splits a single 3.5mm audio output into two separate outputs, enabling you to connect two sets of headphones or speakers to your MP3 player, Tablet PC or laptop computer.
The Headphone Y-Cable allows you to share your favorite songs and videos with a friend while you are traveling or on the move and it features a slim connector molding that fits easily into a 3.5mm headphone jack, even if your mobile device is in a protective case.
This splitter adapter cable is colored to suit white mobile devices, and can be used with any portable device that has a 3.5mm mini jack, such as your iPhone, iPod and iPad . The cable features a compact, lightweight design that takes up very little space in your laptop bag or carrying case.
- StarTech.com White Slim Mini Jack Headphone Splitter Cable Adapter - 3.5mm Audio Mini Stereo Y Splitter - 3.5mm Male to 2x 3.5mm Female (MUY1MFFADPW) - headphones splitter - 15.23 cm
- Cable
- Headphones splitter
- American Wire Gauge (AWG)
- 30
- Length
- 15.23 cm
- White
- Connector
- 2 x mini-phone stereo 3.5 mm - female
- Connector (Second End)
- Mini-phone stereo 3.5 mm - male
- Moulded
- Limited lifetime warranty
- Cable Type
- 30
- Jacket Material
- PVC
- Length
- 15.23 cm
- Plated Connector
- Nickel
- Moulded
- White
- Connector
- RoHS
- Limited warranty - lifetime
StarTech.com 6in Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £2.74 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £3.62 |
StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £4.72 |
StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White | In Stock | £3.47 |
