StarTech.com White Molded Cat6 Patch Cable
Quicklinx: 8TJCWS00 Mfr#: C6PATCH7WH
Length: 2.1m
Colour: White
47 in stock
£3.43 ex VAT
£4.11 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH7WH Cat 6 Patch Cable (7 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 7ft CAT6 Ethernet Cable, 10 Gigabit Molded RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable with Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (C6PATCH7WH) - patch cable - 2.1 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
2.1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
2.1 m
White
Connector
RJ-45 - male
RJ-45 - male
CSA, ETL - up to 650 MHz
8TJC StarTech.com 7 ft White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.83
Length: 2.1m
Colour: White
Stock Status: In stock
