StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad
Quicklinx: 99BWWS00 Mfr#: USBUBLTW
Colours:
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTW White Lightning-to-Micro USB dongle adapter for iPhone, iPod, iPad enables you to sync and charge your Apple Lightning devices using a Micro USB cable.
Perfect for people on the go, the adapter allows you to use your existing Micro USB cable as a Lightning cable, saving you from having to carry multiple cables for your various mobile devices.
The dongle offers approximately 4-inches in cable length and provides a lightweight, portable design that fits nicely inside your laptop carrying case. Plus, the dongle lessens strain on the connector port and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
This durable adapter is Apple MFi certified.
StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad - Apple Lightning to Micro USB 2.0 Dongle (USBUBLTW) - Lightning adapter - Lightning / USB - 10.15 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28/32
Length
10.15 cm
White
Connector
Lightning - male
Connector (Second End)
Micro-USB Type B - female
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Double shielded
24/28/32
Jacket Material
PVC
Shielding Material
Length
10.15 cm
White
Connector
Apple Lightning - male
5 pin Micro-USB Type B - female
RoHS
99BW StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £16.73
