StarTech.com White Apple 8-pin Lightning Connector to Micro USB Adapter for iPhone / iPod / iPad
Quicklinx: B0N5WS00 Mfr#: USBUBLTADPW
Colours:
Hurry, only 2 left in stock!
£10.57 ex VAT
£12.68 inc VAT
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTADPW Lightning to Micro USB adapter for iPhone, iPod, iPad is colored to suit white mobile devices and provides a reliable solution for charging and syncing your Apple Lightning devices using a Micro USB cable.
This compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables you need to carry around with you in order to charge all of your mobile devices.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable Lightning to Micro USB adapter is Apple MFi certified.
StarTech.com White Apple Lightning to Micro USB Adapter - iPhone iPod iPad - Lightning adapter - Lightning / USB
Cable
White
Connector
Lightning - male
Connector (Second End)
Micro-USB Type B - female
Sync and charge
Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
5 pin Micro-USB Type B - female
RoHS
Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
B0N5 StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad In Stock £13.52
B0N5 StarTech.com White Apple 8-pin Lightning Connector to Micro USB Adapter for iPhone / iPod / iPad In Stock £10.57
Price Range Ex VAT: 0 - 50
