Free up space with this wall-mount monitor arm and enjoy optimum viewing with the swiveling extension arm. The premium design ensures smooth, effortless motion and makes it easy to re-position your display, to work in comfort or collaborate with others. The attractive silver finish complements your decor.
The wall-mount system is ideal for business, healthcare, financial or other settings, where you may want to share your screen, or for customer-facing interactive displays.
The wall-mount monitor arm extends 10.2" (26 cm), making it easy to change your screen position. Move the swivel wall-mount freely, to the left or right. You can also adjust the swivel tension.
The robust aluminum design provides a stable wall-mount for your computer monitor or flat-screen TV up to 30". It's ideal for touch-screen stability. The universal display wall mount supports VESA mount monitors (75x75, 100x100) up to 30.9 lb. (14 kg) in weight.
Share your screen with ease. The display wall mount offers a full +180-degree/-180-degree pan, to move your screen left or right. It tilts freely +90/-15-degrees, to adjust the angle up or down. Rotate your screen for landscape or portrait viewing.
Push the swivel arm back to the wall, so your monitor sits just 5" (129 mm) from the wall when not in use.
The quick slide-and-click connections make the monitor wall mount easy to assemble and saves time when setting up multiple units.
- StarTech.com Wall Mount Monitor Arm - 10.2" Swivel Arm - For up to 34" VESA - bracket - adjustable arm - for LCD display - silver
- Product Type
- Bracket (adjustable arm) - wall-mountable
- Adjustable Depth
- Up to 26 cm
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Rotation
- 360°
- Adjustments
- Pan, tilt, swivel
- Recommended Use
- LCD display
- Recommended Display Size
- 13"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 14 kg
- Material
- Aluminium
- Silver
- Package Content
- Hex key, 4 x thumbscrews, 2 x mounting screws, 2 x wall plugs, swivel arm
- 2-year warranty
- Adjustable Depth
- Up to 26 cm
- Material
- Aluminium
- Silver
- Package Content
AV Furniture
- Bracket
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 13"-30"
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Rotation
- 360°
- Adjustments
- Pan, tilt, swivel
- Max Load Weight
- 14 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 13.9 cm x 17.8 cm x 33.9 cm / 1.4 kg
- Limited warranty - 2 years
StarTech.com Thin Client Mount - VESA | In Stock | £26.25 |
StarTech.com Wall Mount Monitor Arm-10.2" Swivel Arm up to 30" Monitors | In Stock | £69.66 |
StarTech.com Wall Mount Monitor Arm-20.4" Swivel Arm up to 30" Monitors | In Stock | £92.87 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.65 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.93 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.94 |
