Connect 4 DVI-D displays to your VHDCI video card. The VHDCI24DVI VHDCI to Quad DVI Splitter Cable enables you to connect up to four DVI-D Single Link displays to your VHDCI video card (i.e. NVIDIA Quadro NVS, and VisionTek AMD graphic cards) at resolutions of up to 1920 x 1200.
- StarTech.com VHDCI to Quad DVI-D Splitter Breakout Cable - VHDCI (M) to 4 port DVI-D (F) Cable for NVIDIA & VisionTek Graphics Cards (VHDCI24DVI) - DVI cable - 22 cm
- DVI cable
- Technology
- Double shielded
- Molded, strain relief
- Length
- 22 cm
- Connector
- 4 x DVI-D - female
- Connector (Second End)
- 68 PIN VHDCI - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Length
- 22 cm
- Black
- Connector
- 4 x 24+1 pin digital DVI - female
- 68 PIN VHDCI (Mini-Centronics) - male
- RoHS
