StarTech.com VGA Video Extender over Cat5 / UTP
Quicklinx: 3ZGVWS00 Mfr#: ST121UTPGB
33 in stock
£84.39 ex VAT
£101.26 inc VAT
The ST121UTPGB VGA video extender over Cat5 allows you to extend your VGA video signal by up to 130 meters (430 feet) and connect up to 4 displays (2 local and 2 remote) from that single source. The ST121UTPGB is a bundled kit including both a local transmitter and a remote receiver unit, offering a complete solution for scenarios in which remote monitor displays are required.
The local unit features a single VGA input as well as two VGA outputs giving you the ability to view and split your source VGA signal to two independent displays locally. The VGA video signal is then sent over standard 4 pair category 5 or better UTP cable to the remote unit which also features two additional VGA outputs giving you the freedom to display your VGA source on up to four monitors in total.
StarTech.com VGA Video Extender over Cat5 / UTP - video extender
Video extender
External
Max Transfer Distance
130 m
Video extender
External
Wired
130 m
1 x VGA - HD-15
1 x VGA cable
FCC
External power adapter
3ZGV StarTech.com VGA Video Extender over Cat5 / UTP In Stock £84.39
3ZGV StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz In Stock £24.80
3ZGV StarTech.com VGA Video Extender over Cat 5 with Audio In Stock £99.29
3ZGV StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.17
Price Range Ex VAT: 50 - 100
