StarTech.com VGA Video Extender over Cat 5 Remote Receiver with Audio
Quicklinx: 76Q7WS00 Mfr#: STUTPEALRGB
Type: VGA
Hurry, only 1 left in stock!
£181.51 ex VAT
£217.81 inc VAT
The STUTPEALRGB is the receiver unit utilized by the STUTPEAGB VGA and audio over Cat 5 extension series. This convenient video distribution system simplifies implementing digital signage solutions by allowing a single VGA source and corresponding audio to be broadcast to multiple displays at up to 300m (950ft) away.
Comprised of one receiver unit per display, as well as a 4 port VGA & audio extender unit (ST124UTPEAGB) or an 8 port VGA & audio extender unit (ST128UTPEAGB), the VGA and audio extension series can transmit a single VGA output and corresponding audio to 4 or 8 displays/receivers over standard Cat 5 UTP cable.
For even more versatility, the VGA & audio over Cat 5 Line Splitter (STUTPEA4XGB) can be used to multiply the number of potential displays by four - allowing the VGA signal and accompanying audio to be broadcast to up to 16 or 32 VGA displays.
StarTech.com VGA Video Extender over Cat 5 Remote Receiver with Audio - video/audio extender
Video/audio extender
External
United Kingdom
Max Transfer Distance
300 m
11 cm x 13 cm x 2.5 cm
270 g
External
United Kingdom
Wired
Max Resolution
1280 x 1024 @ 60 Hz
300 m
Status Indicators
1 x VGA (output) - HD-15 female , 1 x network - RJ-45 female , 1 x audio (output) - mini jack female
FCC, RoHS
External power adapter
11 cm
13 cm
2.5 cm
270 g
50 °C
5 - 90%
76Q7 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
76Q7 StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
76Q7 StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £21.76
76Q7 StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £13.09
Type: VGA
Price Range Ex VAT: 150 - 300
