Convert a VGA signal from a laptop or desktop to HDMI (USB-Powered). The VGA2HDU VGA to HDMI adapter lets you turn the VGA port on your Desktop or Laptop computer into an HDMI output port.
With the VGA2HDU, you can expand your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI.
Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080 (1080p).
For hassle-free setup the VGA to HDMI adapter allows for plug-and-play installation. Plus, with a built-in USB power cable the device is powered using the USB port on your computer. The VGA to HDMI adapter will work with any computer operating system, but when working with a Windows computer the adapter supports native USB audio, allowing you to add your computer audio to the HDMI signal.
Expand your VGA video output
With the VGA2HDU, you can expand your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI. -
The highest video quality
Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080. -
Hassle-free setup
- StarTech.com VGA to HDMI Adapter with USB Audio & Power - Portable VGA to HDMI Converter - 1080p - adapter cable - HDMI / VGA / audio / USB - 26 cm
- Cable
- Adapter cable - HDMI / VGA / audio / USB
- Max Output Resolution
- 1920 x 1080
- Length
- 26 cm
- Black
- Connectors
- HD-15 (VGA) - male (input) , USB (power only) - male
- Connectors (Second End)
- HDMI - female (output)
- USB / USB 2.0
- USB power, 1080p support, active adapter
- 2-year warranty
- Cable Type
- Adapter cable USB power, 1080p support, active
- Interface Supported
- Jacket Material
- Plastic
- USB / USB 2.0
- Length
- 26 cm
- Micro Silicon MS9282 chipset
- Black
Adapters & Converters
- 1920 x 1080
- Connectors
- 15 pin HD D-Sub (HD-15) - male (input) , 4 pin USB Type A (power only) - male
- 19 pin HDMI Type A - female (output)
- Plug and Play, FCC, RoHS, WEEE, REACH, RCM
- 3.5 cm
- 1.5 cm
- 70.7 g
- Shipping Width
- 14.4 cm
- Shipping Depth
- 17.3 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 151 g
- Limited warranty - 2 years
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV | In Stock | £95.65 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p | In Stock | £149.00 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 | In Stock | £90.94 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £25.84 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.92 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £43.85 |
StarTech.com VGA to HDMI Scaler - 1920x1200 | In Stock | £207.80 |
StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered | In Stock | £44.36 |
StarTech.com 3 m (10 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £39.35 |
StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £32.05 |
