StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p
Quicklinx: 9FT0WS00 Mfr#: VGA2HDU
£43.85 ex VAT
£52.62 inc VAT
Convert a VGA signal from a laptop or desktop to HDMI (USB-Powered). The VGA2HDU VGA to HDMI adapter lets you turn the VGA port on your Desktop or Laptop computer into an HDMI output port.
With the VGA2HDU, you can expand your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI.
Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080 (1080p).
For hassle-free setup the VGA to HDMI adapter allows for plug-and-play installation. Plus, with a built-in USB power cable the device is powered using the USB port on your computer. The VGA to HDMI adapter will work with any computer operating system, but when working with a Windows computer the adapter supports native USB audio, allowing you to add your computer audio to the HDMI signal.
  • Expand your VGA video output
  • The highest video quality
    Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080.
  • Hassle-free setup
StarTech.com VGA to HDMI Adapter with USB Audio & Power - Portable VGA to HDMI Converter - 1080p - adapter cable - HDMI / VGA / audio / USB - 26 cm
Cable
Adapter cable - HDMI / VGA / audio / USB
Max Output Resolution
1920 x 1080
Length
26 cm
Connectors
HD-15 (VGA) - male (input) , USB (power only) - male
Connectors (Second End)
HDMI - female (output)
USB / USB 2.0
USB power, 1080p support, active adapter
Cable Type
Adapter cable USB power, 1080p support, active
Interface Supported
Jacket Material
Plastic
USB / USB 2.0
Length
26 cm
Micro Silicon MS9282 chipset
Adapters & Converters
1920 x 1080
Connectors
15 pin HD D-Sub (HD-15) - male (input) , 4 pin USB Type A (power only) - male
19 pin HDMI Type A - female (output)
Plug and Play, FCC, RoHS, WEEE, REACH, RCM
3.5 cm
1.5 cm
70.7 g
Shipping Width
14.4 cm
Shipping Depth
17.3 cm
Shipping Height
3 cm
Shipping Weight
151 g
9FT0 StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £95.65
9FT0 StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £149.00
9FT0 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
9FT0 StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 In Stock £90.94
9FT0 StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £25.58
9FT0 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
9FT0 StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £43.85
9FT0 StarTech.com VGA to HDMI Scaler - 1920x1200 In Stock £207.80
9FT0 StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered In Stock £44.36
9FT0 StarTech.com 3 m (10 ft.) VGA to HDMI Adapter Cable with USB Audio In Stock £39.35
9FT0 StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio In Stock £32.05
