StarTech.com VGA-Over-IP Video Extender
Quicklinx: CFPZWS00 Mfr#: IPUSB2VGA2
Select:
  • VGA
This VGA over IP extender lets you share a VGA display or projector with the wireless or wired computers on your network. The IP extender makes it easier than ever for users to collaborate and deliver presentations in boardrooms and office meetings, with intuitive controls and effortless screen sharing.
The IP video extender supports resolutions up to 1920x1200 and features two built-in USB ports and 3.5 mm audio set, enabling you to connect remote USB devices and speakers with a microphone to your computer from your display. It's the perfect solution for controlling a computer from wherever the adapter is located.
The IP video extender helps you boost your office productivity, by making it easier for users to collaborate and communicate. The included software lets you connect multiple computers and easily switch between which user is sharing their content with the VGA display, unlike some wireless video systems that are difficult to configure and require users to disconnect and reconnect manually.
You can even use the video-over-IP extender to share information with a remote audience, such as connecting to a remote display over an office LAN, to hold remote meetings while you're in another part of the office.
With this IP video extender, you can turn your VGA television, monitor or projector into an IP display that can connect to any Windows computer on your network. It's perfect for conference rooms and classrooms where different ideas are shared by users who bring their own computers.
With a built-in USB hub, you can use your computer to access two remote USB devices at your remote display, enabling you or your customers to control the computer from the remote location. Remote operation can be used to create interactive digital signage, to engage your customers. Or, if you're using the video-over-IP extender as part of your IT infrastructure, you can use the USB extender to add a remote KVM console that you can use to control your server from a remote location.
StarTech.com VGA-Over-IP Extender with 2-port USB Hub - Video-Over-LAN Extender - 1920 x 1200 (IPUSB2VGA2) - video/audio extender - VGA
Video/audio extender
External
VGA
Max Transfer Distance
100 m
AC 120/230 V
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
14.3 cm x 16.8 cm x 6.3 cm
65 g
External
Wired
VGA
Max Resolution
1920 x 1200
100 m
Built-in 2-port USB 2.0 hub
1 x VGA - HD-15 female , 2 x USB 2.0 - Type A female , 1 x audio - mini jack
Foot pad set
1 x USB cable , 1 x network cable
Mounting Kit
Included
FCC, RoHS
External power adapter
AC 120/230 V
14.3 cm
16.8 cm
6.3 cm
65 g
0 - 80% (non-condensing)
CFPZ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.94
CFPZ StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
CFPZ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
CFPZ StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £5.00
