Product
StarTech.com VGA over Cat5 Digital Signage Receiver for DS128 with RS232 & Audio
Quicklinx: 76MDWS00 Mfr#: DSRXL
Type: Media Converter
Hurry, only 3 left in stock!
£182.78 ex VAT
£219.33 inc VAT
Extend and centrally manage VGA video, audio and RS232 control signals to multiple displays. StarTech.com's DS Series Digital Signage Broadcaster VGA Cat5 Receiver offers a comprehensive audio and video extension system, with the added benefit of serial control!
The DSRXL VGA Receiver(s) can be installed at the destination points, allowing you to distribute VGA video as well as the accompanying audio and serial control signals from the connected DS128" text="Serial, Audio and VGA Cat5 Digital Signage Broadcaster (DS128 - purchased separately), all over one Cat5 cable.
Ensuring not only a simple and cost-effective way to extend and control VGA video and the corresponding audio, the DS series (DS128 and DSRXL) also maintains exceptional, high quality video, up to 1600x1200 over a 100m connection. For further extension, you can daisy chain up to five receivers, for a maximum distance of 300m.
StarTech.com Cat5 VGA Digital Signage Receiver with RS232 & Audio - video/audio/serial extender
Video/audio/serial extender
External
Max Transfer Distance
300 m
1 year warranty
External
Wired
Max Resolution
1600 x 1200
300 m
Status Indicators
Wall mountable
2 x VGA - HD-15 female , 2 x audio (output) - mini jack female , 2 x network - RJ-45 female , 2 x RS-232 - DB-9 male
FCC, RoHS
External power adapter
Limited warranty - 1 year
0 - 90%
76MD StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
76MD StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £33.23
76MD StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £16.34
76MD StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.74
76MD StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
76MD StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £21.76
76MD StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.78
76MD StarTech.com 8 Port VGA over Cat5 Digital Signage Broadcaster with RS232 & Audio In Stock £201.82
76MD StarTech.com VGA over Cat5 Digital Signage Receiver for DS128 with RS232 & Audio In Stock £182.78
76MD StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £13.35
Price Range Ex VAT: 150 - 300
