StarTech.com VGA over Cat5 Digital Signage Receiver for DS128 with RS232 & Audio
Quicklinx: 76MDWS00 Mfr#: DSRXL
Extend and centrally manage VGA video, audio and RS232 control signals to multiple displays. StarTech.com's DS Series Digital Signage Broadcaster VGA Cat5 Receiver offers a comprehensive audio and video extension system, with the added benefit of serial control!
The DSRXL VGA Receiver(s) can be installed at the destination points, allowing you to distribute VGA video as well as the accompanying audio and serial control signals from the connected DS128" text="Serial, Audio and VGA Cat5 Digital Signage Broadcaster (DS128 - purchased separately), all over one Cat5 cable.
Ensuring not only a simple and cost-effective way to extend and control VGA video and the corresponding audio, the DS series (DS128 and DSRXL) also maintains exceptional, high quality video, up to 1600x1200 over a 100m connection. For further extension, you can daisy chain up to five receivers, for a maximum distance of 300m.
StarTech.com Cat5 VGA Digital Signage Receiver with RS232 & Audio - video/audio/serial extender
Video/audio/serial extender (receiver)
External
Max Transfer Distance
300 m
1-year warranty
P/N: DS128, SVA5N3NEUA
External
Wired
Max Resolution
1600 x 1200
300 m
Status Indicators
Wall mountable
2 x VGA - HD-15 female , 2 x audio (output) - mini jack female , 2 x network - RJ-45 female , 2 x RS-232 - DB-9 male
FCC, RoHS
External power adapter
Limited warranty - 1 year
0 - 90%
