StarTech.com VGA over Cat 5 UTP Video Extender Receiver
Quicklinx: 5D45WS00 Mfr#: ST121RGB
10 in stock
£60.06 ex VAT
£72.07 inc VAT
The ST121RGB VGA over Cat5 video extender receiver is specifically designed for use as the receiver unit to the StarTech.com ST1214TGB 4 port VGA over Cat5 UTP Extender transmitter, allowing you to split and extend a single VGA source to up to four remote displays.
From the transmitter device, the VGA video signal is sent over standard 4 pair category 5 or better UTP cable to remote monitors, each connected to an ST121RGB Cat 5 VGA receiver - supporting distances of up to 150 meters (500 feet).
A cost-effective video extension solution, this receiver is ideal for a wide range of environments including airports, bus depots, retail, or any large buildings where VGA video needs to be extended to long connection distances.
StarTech.com VGA over Cat 5 UTP Video Extender Receiver - video extender
Video extender
External
United Kingdom
Max Transfer Distance
150 m
Video extender
External
United Kingdom
Wired
Max Resolution
1024 x 768
150 m
2 x VGA (output) - HD-15 female , 1 x display / video - input - RJ-45 female
External power adapter
5D45 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
5D45 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.74
5D45 StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.78
5D45 StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.17
Price Range Ex VAT: 50 - 100
